Question about Samsung DynaFlat TX-P2775H 27" TV
Noise Issues with Samsung Dynaflat TX-P3264H
I have a high pitched noise coming from my TV after about 3 hours of use. If I turn it off for 8 or more hours I can use it again for 3 hours. The noise is not coming from the speakers as I have plugged in headphones and muted the speakers. The noise is located at the back of the TV. I have found no useful tips online as this model doesn't seem to exist and yes I have the 32 inch model which is the standard screen version and not the 16:9. Please help if you know what this may be.
  • Isaiah Crowe Jan 20, 2007
    Got it...It is a flyback transformer that is malfunctioning...any idea how much this part costs?
    Scholar:
  • 168 Answers
Yes ur right that is a flyback that is leaking! it produces a high pitch sound. well if u want to be sure that ur part is genuine. go to the manufacturing authorized service center. for sure they have available part. try also to look into the horizontal cuircuit. there might be something else that was damaged. probably the horizontal output transistor. gud luck
Posted on Jan 20, 2007
  • Noel Andres
    Noel Andres Jan 21, 2007
    well i dont have any idea how much it cost in your location. but to give you an idea, here in philippines a 21 in. color television's flyback cost around 1,500 ph pesos. around $30.
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Duralast 750 is completely dead and make high
high pitch noise is coming from the Flyback Transformer. Faulty power supplies issues.
Aug 31, 2014 | Televison & Video
Replaced the lamp in Samsung hl-s5086w and now T.V. won`t turn on but has a high pitch noise coming from back of set.
The high pitch noise is the color wheel that needs replace the noise is coming from a bad bushing that goes to the color wheel and is a common problem.
Dec 13, 2010 | Samsung HL-S5086W 50" HDTV
I have a samsung neo 32 inch picture tube tv. When I turn it on there is no picture or sound, but there is a light high pitched noise.
That high pitched sound is likely the Horizontal Output section trying to work. It operates at 15,750 Hz or at the upper end of normal human ears.
It will sound like a high pitched whine.
This is a section or your television that you don't want to fool with unless you are quite familiar with servicing your set. There are very high voltages involved and only a qualified technician should tend to this defect. It maybe easy to fix or it may be quite involved. Get an estimate first then decide to go further or not. There is a potential fire hazard here so don't operate your set until this is resolved.
Zashiban
Jun 23, 2010 | Samsung DynaFlat TX-P2764 27" TV
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
High pitch noise
what you are hearing is the mechanical vibrating of coils & or transformers in the tv. 1st and easyest is to hot glue the parts that is making the noise down. if that does not work, removing & reinstalling the part is next. the last is replacement. the most likely parts causing is the 1. horizontal linearity coil, 2. the run or switch mode transformer, or 3. the flyback transformer. good luck.
Jan 09, 2007 | Zenith C27F33 27" TV
Samsung TX-P3271H Noise on cold start
greetings from belize that noise is normal it is just the boost up voltage that the set is hauling to operate.nothing to worry about.good luck.
Dec 21, 2006 | Samsung DynaFlat TX-P3071WH 30" TV
TV doesn't turn on
Washing TV where in a bathtub.. Oh man Tvs cant be washed in a sink or a bathtub.??
Sep 16, 2006 | Samsung DynaFlat TX-P3064W 30" TV
Samsung DynaFlat TX-P2775H 27" TV Logo
139 people viewed this question
Jerry Greenberg
Jerry Greenberg
