Question about Campbell Hausfeld 20 - Gallon Air Compressor
Campbell Hausfeld compresser throwing breaker
When I run my compressor it works fine and builds pressure until it kicks off. But when I use air and to refill the tank the motor hum's and it throws the electrical breaker. If I wait until the motor cools it works fine again. Any ideas???
  • rg69z Jan 21, 2009
    I have an older 20 gl 5 hspwr compressor from Camb Haus. and it does the same thing builds pressure just fine when i use a tool and the compressor starts, it humms and tripps my breaker. I have taken the valves apart including the check valve and found that it is holding and working fine i have removed and polished the reed valves, they too seem to be working fine. my on off switch has been broke for sometime but this problem just surfaced recently. I will bleed of air to 40 psi tank pressure and my compressor will start fine. Cant figure it out?
  • Anonymous Mar 19, 2014
    motor is running but air pressure is zero.
  • 3 Answers
There is a one way valve that only lets air from compressor to tank. If this isn't working the motor is trying to start under the pressure of the tank, and therefore tripping your breaker.
Posted on Nov 30, 2008
  • William D Emmons
    William D Emmons Mar 01, 2015
    i have the same problem same compressor, i took out the check valve and it works. what is the next thing to try?
    New Friend:
  • 4 Answers
I had the exact same problem. Mine was because I had several ounces of water in my tank. I drained the tank and now it works great. I have come across others that have fixed this problem by replacing one or all of these: Check Valve, Unloader Valve, or Pressure Switch. Hope this helps your are someone else with the same issue.
Posted on Feb 14, 2013
    Problem Solver:
  • 7 Answers
It could be that the bearings on your motor are defective or warn allowing the amateur to move sideways in the fields, or the motor is too small to run the compressor. If it's the latter, replace the motor with a larger motor ( more horsepower ). If it's the former replace the bearings or bushings or replace the motor.
Good luck,
shag79
I own a Campbell Hausfeld model WL650800AJ compressor, the problem is that the compressor will not pressurize over about 85 psi..where would be the best place to start troubleshooting?..BTW, there is
The usual problem with oil-less type compressor is the Teflon compression ring and cylinder will fail causing the problem that you describe. Easy to check. With cover removed, turn the pump until the piston is all the way up. With good light, check the condition of the cylinder near the top. If the cylinder looks scratched, air is leaking past cylinder and ring and pressure will not build up enough to reach cut-out. If cylinder looks smooth, then problem is head valve reeds or head gaskets. Indication of bad reeds or head gasket blown, is extremely hot head during fill cycle. Good luck
Dec 07, 2014 | Campbell Hausfeld Air Tools & Compressors
Oilless compressor cycling
Unhook the line to the tank and let the compressor run a while without building pressure. The piston rings need to run in. How is the oil level in the compressor?
Aug 26, 2013 | Campbell Hausfeld Air Tools & Compressors
Second time compressor tries to fill tank blows braker
The compressor pobably has a faulty unloader valve which bleeds the pressure off that is left in the cylinder when the compressor turns off . The unloader valve allows the compressor to start the next on cycle with the cylinder empty. Trying to start the compressor with the cylinder under pressure causes too much current draw and trip the circuit breaker.
Jul 06, 2010 | Campbell Hausfeld 10 HP 120Gallon...
Blowing circuit
Does it sound like it's running the usual speed? If it's at lower speed, it may have a problem in the motor, or a voltage drop condition exists. If speed is near normal, check the reeds in the compressor, or the checkvalve between the head and the tank.
May 22, 2009 | Campbell Hausfeld 26 - Gallon Air...
Compressor runs hot and won't build pressure
THE COPPER LINE IS SUPPOSED TO GET HOT, SCALDING HOT ACTUALLY. THE MOST COMMON REASON FOR COMPRESSORS NOT BUILDING PRESSURE IS CLOGGED AIR FILTER OR THE VALVES IN THE HEAD ARE BROKEN OR NOT OPENING AND CLOSING CORRECTLY. YOU MAY POSSIBLY HAVE A BAD AIR LEAK DOWNSTREAM BUT YOU CAN CLOSE THE DISCHARGE VALVE ON THE TANK TO ELIMINATE THAT PROBLEM. HOPE THIS HELPS OR GET YOU STARTED.
Mar 27, 2009 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld 20 - Gallon  Air Compressor Logo
737 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
