Question about HP Office Equipment & Supplies
I have a CP1215 laser printer. I have just installed a new black cartridge and the printer makes a squeeling noise and sends paper out grey on one side and black on the other.
  • ronrocket Dec 01, 2008
    I in fact rang HP and they said that it was a faulty cartridge which. I contacted Comet from where it was purchased and they exchanged it immediately. When the new cartridge was inserted it worked perfectly again.
    thank you
  • 628 Answers
Try another toner cartridge.
Posted on Dec 01, 2008
What would make my black word barely print when my color is fine
If it's only the black that's effected it suggests that it's a problem with the toner cartridge rather than the printer itself. It may be a faulty toner cartridge, especially if you use cheap compatibles rather than genuine HP branded ones. You could try taking it out of the printer and giving it a good shake to make sure that the toner is evenly distributed in the cartridge. If that doesn't help then I think you need to replace the black cartridge. I had that problem with one of my colour cartridges but everything was fine after I replaced it.
Feb 26, 2015 | HP LaserJet CP1215 Color Printer
Paper tray not fitting in CP1215
Hi, Dorothy,
The CP1215 color laser printer's paper tray defaults to the A4 paper size. However it has an extension at the front that allows for the selection of the JIS B5 paper specification which is longer than A4's 11 inches by the 2 inches you talk about. To release the paper extension, you hold and pull out the middle light blue tab (there are 3 Tabs) that is in the paper tray. The extension will slide out to length of about 2 inches that then juts out when you install the paper tray back into the printer as is in your case. To slide it back, you hold the right-most blue tab and push the extension in back to the A4 paper size. I hope this helps.
Apr 04, 2014 | HP LaserJet CP1215 Color Printer
Samsung printer printing grey
The exit mirror of the laser-scanner unit is dirty. There is a gap above the toner cartrigdge, where the laser beam is comming from. Try to clean with dry soft lint-free cloth.
Apr 08, 2012 | Samsung SCX-4300 All-In-One Laser Printer
I have repalced red cartridge in CP1215 laser
I am not familiar with the model, but the toner cartridges I use have a tab you have to pull that is attached to a long plastic strip that releases the toner. This has to be removed before you can use the cartridge. Just asking to be sure.
Jul 12, 2010 | HP LaserJet CP1215 Color Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
Apr 29, 2009 | Epson AcuLaser C4100 Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Lexmark z53
You will need to do the following diagnostic tests to determine the exact cause of the error: · Remove the ink cartridges · Perform the self test (test B below) · Test the ink cartridges A. To remove the ink cartridges: Switch the printer on by pressing the green button. Open the front cover of the printer. The cartridge carrier should move to the center of the opening. Remove both cartridges. If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand. Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer. Open the front cover of the printer. Inside the printer, locate the silver metal carrier bar on which the print carriage slides. Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion. Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening. Now pull both cartridges out. B. To perform the self-test: Disconnect both the power cable and the USB or parallel cable. After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.) Turn the printer off by pressing the green power button. Hold down the grey paper feed button. Turn the printer on by pressing the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below. C. To test the ink cartridges: Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place. Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step. Turn the printer off using the green power button. Hold down the grey paper-feed button. Turn the printer on using the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly. Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly. If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase. Good luck
Aug 30, 2007 | Lexmark Z53 Color InkJet Printer
129 people viewed this question
Ben Johnson
