Question about Refrigerators
Refrigerator cools intermittently
My Kenmore coldspot side by side refrigerator, model # 106.50264992 (manufactured 08/2000) has started to run intermittently.  The temperature in the refrigerator section increases to as much as 60 degrees and everything in the freezer defrosts.  Then the refrigerator will start to work again for no apparent reason.
Any ideas?
  • allisonwatki Apr 22, 2009
    Thank you so much, this was the solution to our problem.  We finally replaced the thermostat (after a "snowbird" trip) and everything is now working great!
    Sergeant:
    Champion:
  • 291 Answers
Replace the temp control ,,,, when it gets cold enought to cycle off the control wont let it come back on till something shakes it one way or another and the contacts makes to come back on / larry
Posted on Nov 29, 2008
I have a side by side kenmore coldspot model 52259100. The Refrigerator is not cold but the freeze is cold. Help!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
Kenmore coldspot model 106-54592400. The refrigerator is not getting cold enough, has been hovering around 45 to 50. The freezer is working.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 10, 2010 | Kenmore 50522 / 50524 Side by Side...
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
Not cooling or freezing
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
djk
Jun 10, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
263 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
