Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher gets no water
The dishwasher gets no water. I verified that there is power (the drain pump works fine). I did have to clean the drain line out because of a clog that prevented drainage.....when I found standing water in the diswasher. The drain is OK again. The water is on.
The manual suggests to check the inlet filter....but I dont know where to find that.
Is ther a fuse inside the dishwasher that may be broken?
thanks
  • Suzannes Nov 30, 2008
    when I press the on/off button, the letter F appears in the countdown
    window and no water
  • 78 Answers
It is no fuse in dishwasher.
Solution1: Check if the inlet line to d/w is open(usually it located under the sink)
Solution2: To rich a fill valve filter:
1. Shut off water to d/w
2.open kick panel under front door of d/w
3.disconect the water line on left hand side
4.pull filter from center of water valve by nose pliers
5. clean the filter by old toothbrush under the sink
6.put everything back
7. if does not help the water valve needs to be replace
Posted on Nov 29, 2008
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Whirllpool DU8108WKU0 Water remains up to heating elements. Cleaned drain, cleaned drain float and drain line is not kinked.
hi this sounds like either bad drain pump or the pump is clogged, does it make any noise when your trying to drain it? If it does its probably clogged if not its either bad or its not getting any power to the drain pump, the former being more likely, the pump is located on the side of the main sump assembly underneath the dishwasher.
Sean
Mar 27, 2011 | Dishwashers
My Bosch dishwasher SHX46A05UC is not draining
If the water is not draining from your dishwasher, verify the following:
Verify that there is not a clog in the drain hose or air gap. This is typically the reason that a dishwasher won't drain and the clog is usually where the drain hose attaches to the garbage disposal or sink drain pipe. Remove the hose and clear any clogs, then reinstall.
Verify that water from the sink drain is not making it's way into the dishwasher. I would recommend creating a high loop in the dishwasher drain pipe, which is attached to the sink drain, under the sink. The high loop can be fastened to underneath the countertop. This will prevent any water from entering the dishwasher from the sink; it also prevents the dishwasher drain water from making it's way back into the dishwasher
Verify that the pumps drain impeller is working. You can reach the impeller from inside the dishwasher after removing the lower rack, spray arm, and arm support. This typically involves removing a few screws. Once upper parts are removed, inspect the drain impeller, which pushes the water toward the drain port, for any cracks or missing blades. If the impeller is defective, the water will not drain properly and you would need to replace it.
Verify that the drain valve is working; many are controlled with an electric solenoid that opens the valve, sending the water to the drain. There is a chance that the solenoid or the diverting lever could be stuck which would prevent the water to drain. If so, try to free up the solenoid and lubricate the lever. Otherwise the solenoid or pump assembly may have to be replaced.
Verify that the motor is turning/ working and verify that there is power to the motor. If the motor hums but doesn't turn, it may need to be replaced. Motors can get stuck if not used regularly. If the motor is defective, the water will not drain and you would need to replace it.
There are ways to test the pump and motor with a multimeter. If you are not comfortable with doing this, you may want to have a technician test it for you.
Sep 21, 2009 | Bosch Dishwashers
Dishwasher won't drain, the pump seems to be working but it's like it's clogged or something, any ideas?
OK, first using a sponge and bucket, drain out all the water of the dishwasher (DW) as you can. You can also use a towel too.
Check the discharge/drain cover at the bottom of the DW for any obstructions. Sometimes small pieces of all sorts of things get sucked into the drain port.
There should be a protective shroud/cover over the drain and you might have to remove a small hex head screw to get into the drain sump inlet. Some can be popped off without any tools.
Once you have the cover off, be VERY careful in probing the drain area trying to see if there are any small broken pieces of dishes or glasses that may have gotten into the sump area. You'll want to use a towel or sponge to get the water out of the sump area.
If you don't get anything out of the sump drain, it could be that the obstruction has worked its' way into the motor disposal impeller and you'll have to remove the DW from under the counter in order to get at the motor and pump assembly. This will require possible disconnection of the water supply line, AC power line or plug, and the drain line going to the sink or disposal.
Before getting into removing the DW, you can also check the drain line for blockage by disconnecting it from either the sink drain connection or disposal and blow into the line. If it's not clogged, you'll get air coming into the DW. If not, then the drain line is clogged. Also check the Air break connection, mounted on the sink, (if so equipped) and clean it out. You can also pour warm water down the Air break to verify that the line is clear.
If this doesn't work, please check my other solutions under dishwashers for a complete step-by-step for getting to the discharge pump section.
I've seen blockages occur fairly often on these models and it's usually caused by broken bits getting into the discharge pump and jamming the impeller. Once removed, normally the DW will work fine, unless the impeller has been totaly chewed up by the blockage, then you may have to replace the discharge impeller to get it able to pump out properly.
Hope you found this very helpful and best regards!
Aug 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher will not drain.
Check first that the drain hose and the drain lines are not blocked.
Once you ensure that the drain lines are clear, this usually means that the drain pump is stuck, clogged or faulty.
Try first unplugging power cord for ten minutes.
If this does not help, the pump is clogged or defective.
The drain pump must be tested by energising it, if the pump is fine, then this is may be a faulty control, replace the control assembly in this case.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Jun 07, 2008 | Amana 24 in. ADB1200AW Built-In Dishwasher
DISHWASHER WONT DRAIN
Have you checked the drain hose??? It may be clogged to some degree or where it meets either the garbage disposal or t-tailpiece, whichever you have, or where it comes out of the water pump. Also, the impeller inside the water pump might look good but may be worn, and check for broken glass which is hard to see in the bottom drain area at the grate. Hope this helps.
Jan 28, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher doesn't drain
how do you check to see if the pump is pumping? The drain is not clogged or blocked and the line is not kinked. The garbage disposal is not clogged either.
Oct 06, 2007 | Dishwashers
Dishwasher isn't draining
It could be the pump, but not only. Check first that you don't have any clog in the drain line. If drain line is clean, open machine's rear panel and : - Look if the pump works. If it doesn't work check that pump get power (with multi-meter). In case it get power (and does't work), it should be replaced. - In case the pump works - The machine has a drain valve with an electric solenoid (the drain pipe connected to it). When it get power the valve opens and diverts the water to the drain line. Test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck !
May 29, 2006 | Whirlpool 24 in. DP840D Free-standing...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
224 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
