Question about Cisco ONS 15216 FLA SPLITTER BAND COMBINER *2% DISCOUNT COD/WIRE Sys (15216SC48)
Program Kenwood TH-F6 to crossband repeater split
I know how to store the recrive frequency, which is on UHF
I need to know the steps I to store a VHF transmit frequency
so I can work a crossband repeater.
Can I reprogram my tk-2400 with my PC?
No. It is programmed from the Factory on a chip. Preprogrammed. No software will change it, no hacks. Many Motorola radios like that too. It is two watts, Vhf of Uhf, you did not say. If your existing frequencies are Business Band and in the same frequency band (Vhf or Uhf) you can get it to match those.
Oct 13, 2014 | Kenwood Radio Communications
Chanel lock
The Kenwood TK-3312e is a EU version of that handheld If you truly have that model# 3312e and not a TK-2312e.
Then you don't have VHF here the specs for the posted model# you gave.
Frequency Range: 400-470 MHz 5 Watt RF Output 128 Channels/128 Zones Built-In Voice Scrambler QT, DQT, DTMF and 5-Tone Signalling FleetSync Digital Signalling, PTT ID and SelCall MDC-1200 Signalling PC Programming
Jul 01, 2014 | Kenwood Tk-2312e / Tk-3312e vhf / Uhf...
Will not transmit to a repeater
1) are you within range,?
2) is there an obstruction between you and the repeater?
3) do you have the proper PL tome programmed for the repeater?
4) When you press transmit, is the correct input frequency displayed?
Nov 29, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Portable radios
the BF888 is NOT a vhf radio, it is a UHF radio so it will NOT program VHF frequencies
Oct 02, 2013 | Baofeng BF-888 S UHF 400-470 MHz Portable...
What do I need that I can get local TV off air?
You need a suitable VHF/UHF antenna. Then you simply "Tune" VHF/UHF frequencies on the TV and it should find channels and automatically "Lock" onto and store them.
Feb 21, 2010 | Toshiba 22LV505 22 in. LCD TV
Will uniden digital trunking scanner pickup kenwood radio signals
Makes and models make no difference as far as compatibility. Check the frequency coverage of the scanner you're looking at, and compare it to the operating frequencies of the Kenwood. If the Kenwwod is an HF model, the answer is a flat NO. If it's VHF or UHF, most Uniden scanners will be capable of reception. If you need more specific info, such as operating frequencies/modes for specific radios, please let us know.
Dec 28, 2009 | Uniden Radio Communications
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Coverage:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)
For a comprehensive database of active frequencies in your area, visit
Nov 07, 2009 | Uniden BC248CLT Base Scanner
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Computers & Internet Logo
572 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
