My frontload washer stinks. I have cleaned with bleach, mildew cleaner and it smells
  • 121 Answers
You need to run affresh tabs thew it that will take care of it there aer made by w.pool
Posted on Nov 29, 2008
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
I have sour mildew smell problem with my clothes
Look inside the door to the gray rubber ring gasket thingy. Pull apart the sides and look in. Betcha a dollar to a donut there's mold in there. It's a gross, nasty problem whirlpool customer service doesn't give a damn about.That's where water sets after wash cycles. There are tablets call "Affresh" which can be run with hot water for a cycle to attempt to clean out the mold/mildew. Not cheap, not fair, and probably will only be a start to a maintenance type cure if you've had the washer for awhile. May take some manual labor with bleach as well. NOT a sanitary washer. This is an unbelieveable problem with a washer. Piece of ****.
Aug 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
My Maytag Neptune TL has a moldy smell that I can't seem to get rid of. I've used a steam cleaner to blast away mold I've found around the rim and other parts I can reach, and I've run cycles of just hot...
Take off the round agitators one at a time, by popping off the center cap and use a hex driver to remove the screw. Tilt out aggitator, and clean back of agitator, hyousing and gear box of the moldy/mildew build up..its kinda gross. That is where the stink comes from.
Jul 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Strange smelling towels - HE Frontloader
Try running the washer with detergent and a box of baking soda--no clothes--and HOT water. Do you have very hard water in your area?
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MOLD
Hello Friend, Sounds to me like you have a problem with the quality of your water supply going into your washer. Water quality could be a possibility. If the water contains alot of micro-organisms this could be the problem. When you are not using your front load washer the door remains closed trapping in moisture causing mold and mildew to grow. If you just repeat the cleaning process once again with bleach you should'nt have this problem anymore if you leave the washer door partially open when not in use. Happy to help, Tim.
Jun 25, 2009 | Frigidaire GLTF2940ES Front Load Washer
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Super Capacity Washer - Mildew smell
run the washer, with no clothes,
and 2 cups of bleach instead of detergent.
kills any mould in the washer
at least until you find the original cause, it wont stink
Oct 13, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Stinky clothes
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
Washer door ring has mildew on it and is causing my clothes to smell moldy. What can be done to get rid of this? I've used bleach, and cleaners directly on the rubber ring, but with out success.
Unfortunately, when mold and mildew impregnate the rubber door boots on these models, it's nearly impossible to get it to go away. I would recommend replacing the door boot and follow these diligent preventive measures to keep the problem from coming back: 1. Check the area in and around the door boot after each wash for lost articles of clothing like underwear and socks. Also, clean out any lint or debris that collects under the boot. You might want to think about using a mesh garment bag for small items in the future. 2. Wipe the area periodically with a towel to get rid of the accumulation of soap deposits and dirt. This means wiping BEHIND the door boot where it meets the wash tub as well. I recommend waiting until you get ready to do a load of towels. Clean the area with a towel, then throw it directly in the wash. 3. Leave the door OPEN between washes to allow the door boot to air dry. Due to the nature of these door seals, they seal air tight and create an environment for mildew and mold to grow. 4. Run the washer with no load on the hottest cycle you have with nothing but bleach about once a week to keep bacteria to a minimum, and to flush the drain lines and pump. The door boot costs about $80 to replace, but it may be your only solution to getting rid of the smell and bacteria. Let me know if you decide to replace it. I can give you some pointers.
Jul 28, 2007 | Kenmore 44072 Front Load Washer
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
