Question about HTC TyTN Smartphone
Computer has stopped recognizing a connection with my TyTN phone.
I purchased my HTC TyTN almost 2 years ago. Until 4 months ago, I would sync my phone to my computer (running Windows XP) by using ActivSync. I just got a new computer with Vista. I was able to sync 2 or 3 times (Vista runs a different syncing software but still is made by Microsoft) and then suddenly my computer stopped recognizing the connection with the phone. I have been told to download Windows Mobile 6 (which I did) but without a viable connection, I have no way of upgrading or installing anything on this phone. I did a hard reset but that didn't help. After the hard reset I even tried connecting to my old computer running Windows XP which allowed me to use ActivSync but that computer did not recognize a connection either. Does anyone have any ideas on how I can create a viable connection between the phone and the computer?
  • 5 more comments
  • margaret142 Dec 02, 2008
    I would agree that potentially the only problem with my TyTN HTC phone's ability to be recognized by my computer as being connected would be to replace the USB cable. But we even tried using the Bluetooth feature to synchronize and it didn't recognize the connection either!Do you have another suggestion?
  • margaret142 Dec 07, 2008
    I still have not received any constructive responses yet. Can someone help me?
  • margaret142 Dec 09, 2008
    I downloaded Windows Mobile Device Center as suggested by the most recent advisor. All goes well (it even seems to pass the authentication test but I don't know if it is checking the software on my computer or my phone). Then when I launch the Mobile Device Center it says the phone is not connected when in fact it is. This is SO frustrating!!
    How do I turn off Norton 360?
    Thanks for your question about the rom version. I checked on the phone and the rom version is 1.18.256.2. Sounds a long way from the rom version you spelled out.
    Where can I find a new usb driver on the web? The suggestion about the usb wire has been brought up before. Can you suggest where I could order one of these?
    My bluetooth is working great but even with the Bluetooth feature turned on both, the sync option in ActivSync (on my phone) is still greyed out (that is the same indication I get when I use the USB cable which is why I don't think the problem is the USB cable). All the information supplied by the advisor about trouble shooting synchronization and turning off the Norton firewall, references ActivSync in the directions which is not on my computer. ActivSync does not run in Vista. It is the Windows Mobile Device Center so all the information about how to turn off the firewall between the device and the computer doesn't seem to apply. I looked down through the list of programs that the firewall addresses and the Windows Mobile Device Center was not on it. Thank you to everyone who is suffering through this situation with me. I'm using everyones advice and trying everything. I would give up but this phone is only 18 months old and was hugely expensive. Tossing it in the garbage is not an option......
    Scholar:
  • 134 Answers
How do I synchronize my PDA phone with my computer using Bluetooth?
1. On your PDA phone, tap Start > Settings > Connections tab > Bluetooth. 2. Tap the Mode tab, select the Turn on Bluetooth and Make this device discoverable to other devices options, then tap OK. 3. In your computer, open Bluetooth Settings (or Bluetooth Configuration) from the system tray or the Control Panel, add a new device, then search for the PDA phone. 3. Select the Use my own password key option and enter a passcode. When prompted on your PDA phone, enter the same passcode. 4. In Bluetooth Settings (or Bluetooth Configuration) on your computer, you will see that the COM port connection name is Pocket PC (or your user name). Do not include Serial COM 4 corresponding COM number. If no COM port is present, you must manually add a new COM port. 5. In ActiveSync or Windows Mobile Device Center on your computer, open the Connection Settings dialog box. Select the Allow connections to one of the following check box and then select the correct COM port. 6. In ActiveSync of the PDA phone, tap Menu > Connect via Bluetooth.
Why can't I synchronize the PDA phone with my PC using the USB cable?
Make sure Outlook 2003 or later version is installed on your PC. If Outlook is installed on your PC but you have never used it, launch Outlook and create a personal mail account before you connect the PDA phone. • Check if ActiveSync 4.5 or higher version is installed on your PC. If you are using Windows Vista, sync using the Windows Mobile Device Center. • Click File > Connection Settings in ActiveSync or click Mobile Device Settings > Connection settings in Windows Mobile Device Center, and then select the Allow USB connections option. • Disable your PC firewall or antivirus software. • Visit this website for additional information: http://www.microsoft.com/windowsmobile/help/activesync/default.mspx
What is the difference between synchronizing with a server and synchronizing with a PC, and which should method I use?
Synchronization to a PC is for use when your information is stored in Microsoft Outlook on your PC. This method, which requires a USB cable, infrared or Bluetooth connection, will sync data only while your device is connected directly to your PC. Synchronization to a server allows your device to sync, over-the-air (OTA), directly to a Microsoft Exchange 2003 or 2007 Server. This allows you to update your Outlook e-mail, contacts, calendar and tasks information securely from any location using the data connection of your device. In order to use this functionality, you do not need a PC running; however it does require your IT administrator to enable you to use this service.
I hope it helps!!!
Posted on Dec 09, 2008
  • Fernando Cruz
    Fernando Cruz Dec 09, 2008
    A conflict occurs when
    there is a connection breakdown during synchronization, especially when
    the PDA phone and PC are changing sync items simultaneously. You may
    tap Manage Conflict to specify if you would like to retain the data on
    your device. You may also encounter a synchronization conflict after
    opening and/or editing a file on the PDA phone. If this happens, close
    the opened and/or edited file, and then try to sync again.
    Try this link for upgrade, driver and application
    http://www.htc.com/europe/supportdownloa...
    I hope it helps!!!
    Scholar:
  • 81 Answers
I'm just new at Fixya, but I would like to suggest something might can relieve your situation now. this really simple,
auto update your system to Microsoft for your system and drivers.
by clicking shield icon at the right task bar. along with the time.
there are multiple updates that your going through. and it can help.
at the link below you can update your vista to Microsoft:
http://www.microsoft.com/windows/downloads/default.aspx
Posted on Dec 08, 2008
  • Alver Clamonte
    Alver Clamonte Dec 08, 2008
    Silverlight updates can active your auto updates requirements of your system. please updates that one.
    http://www.microsoft.com/silverlight/res...
  • Alver Clamonte
    Alver Clamonte Dec 13, 2008
    try to update in your computer manufacturer, find out if there available new drivers for your devices. because now a days, Vista OS there still many incompatible issue, this depend on Unit manufacturer, Integrate Drivers uses by manufacturer and your Vista version.
    the most recent OS MS Vista is the Vista Ultimate Black Edition 2009 (by Benjamin) the most reliable in all Vista OS. and that why I recommend to update to Microsoft website for OS Integrated drivers issue. browse the MS website all update applicable to your system.
    hope this can help your situation.
    Master:
  • 763 Answers
Is there a settings on your phone that would trigger the connections between your phone and your computer? like a switch or configuration to be able to recognize. if not then try to install a usb driver which is downloadable on the internet and try another usb wire.
thank you for using fixya
CHARCOIS
  • 4,338 Answers
Check your rom version. go to Start > Settings > System Tab > Device Information.
Rom update Version 3.57.502.2 WWE (WM 6.1)
has been causing sync errors.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 07, 2008
  • 6,487 Answers
Make sure all security software are disable when you try to do a sync because sometimes security software can block the connection of those devices...
  • 734 Answers
You need to install driver that compatible with windows Vista so download it from ----http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center.mspx
Posted on Dec 02, 2008
  • 162 Answers
Data Cable gets damaged overtime Replace the cable as the phone WAS detected on both machines.
Posted on Nov 29, 2008
  • uten
    uten Dec 07, 2008
    get vista drivers for your unit since it does not work with bluetooth either.
  • 1,879 Answers
It is the usb cable -
worked with the XP before
worked 2-3 times on VISTA
now not detected on both VISTA and XP
replace USB cable
  • monk3ybidzness
    monk3ybidzness Dec 07, 2008
    probable cause is Windows Update (which you can't undo)
    HTC has recently released Windows Vista compatible drivers for its
    UMTS/HSDPA capable devices, namely the HTC TyTn/Hermes and HTC Breeze
    (aka HTC MTeoR). If you use your TyTN or MTeoR as you wireless
    broadband modem and connect it via USB to your PC, it can happen that
    Windows Vista doesn't find the appropriate drivers. If so, you can
    download them now from HTC Europe's support page to make Windows Vista
    working proper with your Windows Mobile Pocket PC.
    http://www.htc.com/europe/support.aspx
  • monk3ybidzness
    monk3ybidzness Dec 09, 2008
    either VISTA or HTC must release a WORKING driver in order for it to work.
    President:
  • 2,110 Answers
It seems to be your USB Data cable having some problem..try to use a new data cable...
  • Sibananda Jena
    Sibananda Jena Dec 02, 2008
    first uninstall then re install active sync. ..then restart computer and connect the data cable..if problem persist then replace the data cable,...
    Sergeant:
  • 276 Answers
Just uninstall the phone software and again reload it .this will get the phone to recognize.
  • smarttech Nov 29, 2008
    How to connect phone to computer via USB Port and transfer files .click this link
    http://forum2.mobile-review.com/showthre...
    to uninstall do the following.
    My Computer > Control Panel > Add or Remove Programs > Uninstall Phone Manager.
    My Computer > Control Panel > System > Hardware > Device Manager > Ports (COM and LPT) > Uninstall all the ports except for main ports such as Printer ports (You'll know by the word printer in it) or such.
I purchased an HTC TYTN II phone but do not know how to sync it to my PC. I did not recieve a software CD. I have already downloaded Windows Mobile Device Center to my computer -- it runs Windows...
The htc handsets all come with software that allow you to connect to the computer, it will interface with Windows. The physical connection is the USB on your PC to the Mini USB on the phone. This HTC come with this lead (your probably using to charge the unit).
Once connect you can download all sorts of things.
Hope this helps
Sep 10, 2011 | HTC TyTN II Smartphone
Cannot sync with my computer to my wildfire s mobile
hello Jb,
Setting up HTC Sync to recognize HTC Wildfire S
Connect HTC Wildfire S to your computer using the USB cable that came in the box. When
HTC Wildfire S prompts you to choose a type of USB connection, tap HTC Sync, and then tap
Done.
Wait for HTC Sync to recognize HTC Wildfire S
.On the Device setup screen, enter a
name for HTC Wildfire S.
Click Save. The Device panel then opens.
Aug 17, 2011 | HTC Wildfire
My htc desire will no longer sync with my PC it asks to insert disk into drive E
Your solution
Setting up HTC Sync to recognize your phone
After installing, set up HTC Sync to recognize your phone.
1. From the Home screen, press MENU, and then tap Settings > Accounts & sync.
2. On the Connect to PC screen on your phone, tap HTC Sync and then tap Done. Your phone attempts to find HTC Sync on your computer. Wait for a few seconds for the process to finish.
3. If your phone displays a message indicating that it's unable to find HTC Sync, try disconnecting and reconnecting the USB cable, and then repeat step 2.
4. When the Phone Connection Wizard is displayed on your computer, click Next.
Enter the name you want for your phone, and then click Finish.
Check the HTC Sync icon at the bottom-right side of your computer screen. If it appears green in color, that means your phone has successfully connected with your computer and HTC Sync recognizes your phone
If still no go try this .
Unplug the phone from the PC, restart both the phone and the PC. When the PC is done booting, plug your phone in and see if the autorun box pops up.
still if nogo try this .
you have to select disk drive (when plugged in via notification area) to be able to view the drive in windows and htc sync to use htc sync.
May 27, 2011 | HTC Desire Cell Phone
Change language from italian to english.. htc tyn II pro, thank you
Hi there!
You'll need to follow this steps to change the language of your HTC TyTN II
<p>1. Make sure you install Microsoft ActiveSync in your computer. Do a first time sync between your phone and the computer.</p><p> 2. Disable any screensaver and/or hibernation in your computer.</p><p> 3. Sync and again and flash with the HardSPL rom from OliNex. You can find this HardSPL software from here >> http://wiki.xda-developers.com/uploads/Unsigned_HardSPL_for_Blackstone_OliNex.zip The flashing completes in under 2 minutes.</p><p> 4. Reboot device. TouchFlo3D will launch into the native language the device originally came in. The new rom now enables you to flash other language roms, even official ones from HTC, bypassing licensing and verification checks (of course you should have the relevant ROM).</p><p> 5. Finally, flash again with the newset WWE (World Wide English ROM. You can download the official English ROM here: http://www.htc.com/hk-en/supportdownload.aspx?p_id=13&cat=2&dl_id=287</p><p> 6. Device reboots in english, or the language of the ROM you flashed.</p>
Take note that by doing this, the warranty of your phone will be voided.
Hope this helps
Apr 28, 2011 | HTC TyTN II Smartphone
My computer can no longer recognize the device
I assume you have tried all trouble shooting with clearing drivers from USB ports and all the reinstalls plus the correct MS Active Sync. If none worked, then most probabely the USB port of your HTC is damaged or disconnected from the connections on the board. If you are somewhat handy, it is not that difficult to open and inspect. Just be careful not to tear any of the flex cables.
Apr 27, 2009 | HTC TyTN II Smartphone
Htc tytn 2 background picture not working
I have a simular HTC phone and it has no setting for tile at all. It would appear you have a defective unit. Was it recently purchased? On my phone I have 30 days warrenty with the phone carrier and a year with HTC. Check to see what you have in the warrenty and get it in soon.
LB
Nov 30, 2008 | HTC TyTN II Smartphone
EDGE/GPRS not working in HTC TyTN II with Windows Mobile 6.1
There is an auto configuration guide that you must use after the update. Look for it in your system tabe under settings
Oct 22, 2008 | HTC TyTN Smartphone
HTC tytn 2
Hi
Not sure what you need the disc for. All you need is for Active Suync to be operational on your PC. Best to download the latest version of Active Syn. Its easily found by Googling Active Sync Download.
AS will already be installed on your PC (might be an older version) - so what happens when you connect the TyTn?
Mike
Sep 26, 2008 | HTC TyTN Smartphone
I dont have the installation CD for TYTN. I cannot connect my htc TyTn to my computer any help please
You shouldnt need the instalation cd for windows, If you are running xp then you need to download and install active sync from here
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync45.mspx
If you are running vista then active sync wont work you will need to download Windows Mobile Device Center 6.1 abailable here
That should take care of your problem
If it works then dont forget to rate the me :)
Aug 22, 2008 | HTC TyTN Smartphone
HTC TyTn II data connection problem
It keeps connecting because an application keeps wanting to access the internet.
Make sure you set your email to manually download messages.
Turn the Weather Tab off in HTC Home Screen as it automatically downloads the weather.
Turn off "QuckGPS"
Disable Error Reporting to Microsoft in the System settings
Also remember MMS messages will require internet connection.
Everytime you send a MMS or receive a MMS your phone will connect to the internet.
Jun 20, 2008 | HTC TyTN II Smartphone
HTC TyTN Smartphone Logo
51 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
