Question about Apple iMac G4 Desktop
I just got my G4(lamp) and I can't figure out the digital audio.
Mostly I just need the right cable, however, I have no idea where to start, which brings me here,  Thanks.
  • Sam Kirsch
    Sam Kirsch May 11, 2010
    The title is cut off, so we cannot see exactly what cable you are looking for.
  • 148 Answers
Try this;
http://store.apple.com/us/product/TR841LL/A?fnode=MTY1NDA3Ng&mco=MjQzNTYxMA&p=1&s=topSellers
Posted on Dec 11, 2008
Mac G4 Digital Audio Model. Unit is, suddenly, completely dead. Is a good backup battery (1/2AA 3v), needed for a power start? Is there a separate fuse anywhere in the unit, i.e. within the Power Supply...
Processors are liquid cooled on G4s check and see if there is fluid in the bottom of case . if there is go see ur Apple dealer, They replaced mine.
Oct 07, 2010 | Apple Power Mac G4 Desktop
Install an Airport card in a G4 Tower
There are six models of Power Mac G4 computers: AGP Graphics, PCI Graphics, Gigabit Ethernet, Digital Audio, QuickSilver, and QuickSilver 2002. You cannot install an AirPort card in the Power Mac G4 (PCI Graphics); the rest accept original version 1 Apple Airport cards. The card is simply inserted through an opening in the PCI card guide and seats itself into a socket on the logic board. Then you attach the loose antenna cable to the hole on the end of the Airport Card. You're done.
Oct 16, 2009 | Apple iMac G4 Desktop
Toshiba 27A250 S-Video Recognized by Mac But Not Viewable on TV
Is your TV NTSC or PAL
and does your Mac have a video output setting box ?
make sure your mac is putting out the correct video standard
and try another Y\C 'S-Video Cable'
Jun 16, 2009 | Televison & Video
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Imac g4 flat panel 1.0 gb power lamp replacement
this led indicate your mac is sleeping, don't panic
Jan 06, 2009 | Apple iMac G4 Desktop
Need digital audio cable.
are you saying you want to use the optical out feature?
simple way would be to just use an adapter and then a standard optical cable. http://www.amazon.com/Toslink-To-Optical-Mini-Adapter/dp/B0002MQGRM
is an example of one
another option is
http://www.amazon.com/6ft-Toslink-Mini-Cable/dp/B000FMXKC8/ref=pd_cp_e_1?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B0002MQGRM&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1Y124Z337KNRACB3NJE4
Nov 29, 2008 | Apple iMac G4 Desktop
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
Hooking up DVD player to proscan TV. Video is coming thru but there is no sound.A digital cable box from comcast is in the mix. I can usually figure things out but I am stumped on this one. Any ideas?
Hi,if you have video and no sound you have hooked up the dvd with component cables but you still need phono cables for sound,run these from the dvd audio output to tv audio in,if you have a amp for sound come from dvd out to dvd in on your amp.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
Apr 05, 2008 | Televison & Video
Apple iMac G4 Desktop Logo
32 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
