Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Picture is getting darker and darker
My hitachi is only one year old and the picture has been getting darker and darker over the last month. i have the setting as bright as it will go, but it is getting almost to dark to watch. has anyone else had this problem and if so, what is the fix?
  • 2 more comments
  • Anonymous Nov 08, 2007
    i have the same promblem...tv is only a couple years old
  • erca Nov 15, 2007
    picture getting darker,unable to get any brighter
  • Anonymous Dec 27, 2007
    picture is getting darker and darker
  • Anonymous Jan 03, 2009
    picture is too dark
I was actually out looking for another set until I read this. I fixed just in time for the Superbowl!! Thanks!
One thing to note.......The first thing I did on the focus block was crank up the screen adjustment for the red lamp (upper left) to see if it made it better or worse. This must overdrive it or something because I heard a faint "pop", then the screen shut off. I unplugged it, turned that knob all the way down, waited 5 min., then turned the set back on. The screen came back on and I slowly returned that knob to it's original position. Everything was fine after that, but I'd avoid adjusting those top 3 knobs.
Posted on Feb 04, 2009
I have the same model with the same problem. i just paid a repair man to fix it. he adjusted the focus block. if you remove the lower front panel, then remove this other access panel under that there will be a block with 6 knobs on it to the upper left of the access port. 2 for each projector. play with the knobs till you can read the menu options again (mine was so dark i couldnt). then turn your color all the way down till its black and white. then adjust them until you get a nice perfect even gray. then turn your color up and adjust your settings. thats it in a nutshell. it took the pro about a half hour or so. if it takes you longer dont feel bad. i hope me paying for this service helps you guys out.
Posted on Jan 10, 2008
    Sergeant:
  • 308 Answers
The screen/focus block assembly has caused problems with this model in the past. Sometimes it can be readjusted, other times replacement is called for.
Posted on Jan 22, 2007
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
55HDX99 picture is getting darker and darker. Have adjusted settings but no improvement. It's 4 years old and has probably less than 7000hrs.
I would try that if available but suspect a bad board somewhere in the set--average life on all Plasma sets is 3-5 years so maybe time to upgrade to a new set?
May 30, 2012 | Hitachi 55HDX99 55 in. Plasma HDTV
Picture has been slowly getting darker and darker over the last year. TV is just over 1 year old. LG's 52LG50.
how much out of warranty is it?
you should still get some support under the sale of goods act, in the UK, not quite sure anywhere else.
Take a look at this site if you are in the UK -
http://www.berr.gov.uk/whatwedo/consumers/fact-sheets/page38311.html
If you are in America then you will have to dooyour own search i'm afraid.
Hopefully this will help you.
When you spend this much on a tv it should last longer than 1 year, especially if someone is paying for it on installments.
Jan 23, 2010 | LG 52LG50 52 in. LCD HDTV
Darker picture
Clean the lenes inside of the TV and the mirror and screen (a little dust build up on these three things adds up quick!) also if you smoke that can build up too! these tvs have too be cleaned inside
Nov 28, 2008 | Hitachi 57F500 57" Rear Projection...
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture getting darker
The tv has a room light sensor,
shine a bright light at it , does picture get brighter?
other wise when it is cool open the bulb door , is it coated or blackened, Don't touch bulb at all.
and a heavy covering of dust on internal mirrors will cause the same effect.
you will need help to clean it.
Jan 26, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hitachi tv
  • Clean the Spark Gaps on each CRT PWB.
  • Remove the Cap, clean the contacts with thin fine sand paper then blow out excess.
  • Reseal
  • These are things you should know that will require experience in what you are doing. This is the area of High Voltage. So take precautions. More info at ctechnicians.com
  • Dec 29, 2007 | Hitachi 43FDX01B TV
    Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
    316 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
