Question about Cisco ONS 15216 FLA SPLITTER BAND COMBINER *2% DISCOUNT COD/WIRE Sys (15216SC48)
Need to listen on UHF Then Transmit on VHF
Please tell me how I can program my Kenwood TH-F6 handheld to work a crossband repeater split.
I want to listen to my repeater on 443.725
and when I press the key I want my handheld to transmit on 145.81 MHz
I know how to store 443.725, so all I need to know how to store a transmit frequency of 145.81 so I can hit my remote base station.
Thanks in advance,
Bob Haynes WB4AKA Valrico, Florida
(813) 657-1200
Chanel lock
The Kenwood TK-3312e is a EU version of that handheld If you truly have that model# 3312e and not a TK-2312e.
Then you don't have VHF here the specs for the posted model# you gave.
Frequency Range: 400-470 MHz 5 Watt RF Output 128 Channels/128 Zones Built-In Voice Scrambler QT, DQT, DTMF and 5-Tone Signalling FleetSync Digital Signalling, PTT ID and SelCall MDC-1200 Signalling PC Programming
Jul 01, 2014 | Kenwood Tk-2312e / Tk-3312e vhf / Uhf...
Will not transmit to a repeater
1) are you within range,?
2) is there an obstruction between you and the repeater?
3) do you have the proper PL tome programmed for the repeater?
4) When you press transmit, is the correct input frequency displayed?
Nov 29, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Portable radios
the BF888 is NOT a vhf radio, it is a UHF radio so it will NOT program VHF frequencies
Oct 02, 2013 | Baofeng BF-888 S UHF 400-470 MHz Portable...
I bought a Kenwood model TK 8102/TK 7102 how do i program it?
I bought Kenwood TK 7102 VHF radio, but it was programmed and I can listen the dispatcher but can not transmit to him. Any solution please help.
Aug 20, 2010 | Kenwood TK-3101 Radio
Programing Motorola HT1000
The HT1000 is a dealer programmable unit. The DTMF keypad on the front of the unit would be nonfunctional unless you were using it in conjunction with a repeater system which allows for DTMF phone capabilities. Otherwise it is just an extra place for dust, dirt and moisture to get in the radio. If you are working as a firefighter, it is highly recommended you get a holster to cover the front of the radio to prevent moisture from getting to the component board through the keypad area. As for telling if the radio is VHF or UHF, typically the 4th digit of the model number will tell you. If it is an R it is UHF; if it is a K it is VHF. Here is a link to a reference chart:
Jul 02, 2009 | Radio Communications
Looking to build a two way radio system.
You will have to have a vehiclular repeater that is in another band than the mobile so if your portable hand held radios are on UHF then I would advise a VHF high band repeater set up.
It will have to be a cross band setup meaning it will recieve UHF and transmit on VHF and also the opposite direction.
It will have to be programmed with CTCSS or PL of some kind to avoid interference and don't forget it will need to be FCC licensed for those frequencies if it is in the Business band.
Some mobile radios can be wired up through a mini controller and run that way if it is compatible.
Apr 28, 2009 | Motorola For SP50 7.5v 1500mAh NiCd...
By keeping the PTT button pushed, if you get a rapid beep and the red led is blinking, sounds like a bad battery. Batt voltage is a nominal 7.5v. anything lower than 6.25v and the low battery beep starts. A rapid beep, and no red led blinking, an error in the transmit freq.
Mar 01, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Computers & Internet Logo
101 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
