Question about Kenwood KR-V9080
No sound coming from speakers
Just moved it and it may be hooked up wrong
Hooked the stereo up and got power to but no sound coming out speakers but i try home speaker it work so what did i do wrong ?
if im understanding correctly what you wrote. you hooked up the headunit to the car and no sound from speakers, then you hooked up a single house speaker up and that speaker works fine. the Ohms on the car speakers might be too high, but most likely sounds like the wires to the speakers are bad.
Nov 21, 2013 | Cars & Trucks
Power light is on but no sound from the speakers
Have u hooked them up correctly ? I did that once n the left n right were wrong way around
Oct 29, 2012 | Altec Lansing VS4121 Speaker
the wire probably got crossed or hooked up wrong and burned the speaker up smell the speaker if it has a burned smell they are no good anymore
Sep 29, 2012 | JVC AM FM CD DET FACE CAR STEREO
Unhooked everything from computer to move, now i have hooked speakers back up, and there is no sound.
Most of the time that problem is that they are plugged into the wrong port. Make sure that they are plugged into the green port on the PC or the one with a logo of sound waves with an arrow going towards the center or simply a speaker logo.
Best of luck
May 25, 2011 | Dell AS500 Sound Bar Computer Speakers
No sound
If you know your speakers are working and there is nothing wrong with them go on your computer and go to sound settings in control panel and adjust treble bass and volume.
May 30, 2010 | Insignia 2.0 Speaker System (2-Piece)
Wiring
1st make sure your amp is coming on. Use another speaker that you have heard play to test it.
Next test the woofer with a 9 to 15 volt battery. Touch the battery leads quickly across the + and - on one side at a time. The speaker should move and make a pop on both voice coils.
If the amp plays and speakers play, then you need to know the power rating and impedence stability of both amp and speakers. That will determine how they are wired up.
Jul 28, 2008 | Digital Audio DA8012 12" Subwoofer Car...
Sound Problems on my Dell
It should be having onboard sound card, check from Bio's setup whether the Audio is ON. also check in control panel sound and media devices and check the volume maybe it's very very low or on mute. Also try with other speakers
Feb 28, 2008 | HP JBL Platinum Computer Speakers
No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Sep 10, 2007 | JVC RX-770V Receiver
24 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
