Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
How to wire SMEG Oven SA9066CER
Hi i have a smeg oven (SA9066CER).
I am connecting it to a 220-240V terminal.
The back of the SMEG has 6 connections.
As far as i can understand from the Manual, the live (red) wire is connected to input 1. The bacl wire is connected to input 4 and the earth (green) is connected to input 6.
Can anyone tell me if this is correct?
Thanks.
  • 417 Answers
Yes that sounds o.k
Posted on Nov 30, 2008
SMeg duco4ss wiring diagram
Request a wiring diagram for model duco4ss directly from Smeg.
May 13, 2018 | Smeg Ovens
Oven fan working. just no heat.
Most common problem will be a faulty oven element. Also check the wiring at the oven element terminals, it could be burnt off.
Feb 17, 2011 | Smeg SE280X Stainless Steel Electric...
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
Smeg oven is "locked", needs unlocking or resetting
Use a flashlight and look into the hole from where you normally feel hot airflow. Locate the hook holding the door on the left side. Using a thin screwdriver or a knife gently push the hook to the left. Voila! The door is open and functions are back working normally. Also known as Error 4 interlock problem. This will depends on the model of the oven
Jan 30, 2010 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg F67-5 oven not heating up
most likely is the element - easiest way to check is with a multimeter
another way but be carefull, is to connect the element direct to mains and see if it heats
to check the thermostat, just link across the terminals
Nov 26, 2008 | Ovens
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
312 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Smeg Oven Expert? Answer questions, earn points and help others
