Question about Microsoft Xbox 360 Console
When i insert a disk into my xbox 360 and prees close it opens back up and i close it again and the same thing happens,what is the fix for this?
    Scholar:
  • 22 Answers
Though i fixed the Disc Read Error myself within anhour but please test the below method at your OWN Risk. Please alsonote that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys.
Posted on Apr 09, 2009
How do i fix the disk drive on an xbox 360
http://www.pakgamers.com/forums/xbox-hardware-faq-guides/6157-how-fix-open-tray-error-another-solution.html
ezinearticles.com/?How-to-Fix-Xbox-360...Red...Error&id... -
forums.xbox-scene.com/index.php?showtopic=484726&st... -
OK use those links above i am sure you will find help there.
Mar 25, 2010 | Microsoft Xbox 360 Console
360 tray opens and closes by itself
broken faceplate or broken dvd tray. Call MS support.
Mar 20, 2010 | Microsoft Xbox 360 Console
Xbox 360
Most likely your disk or dvd drive is dirty. Run the disk through a disk cleaner and run a dvd cleaning disk through your drive.
If that dos not work, try removeing disk, close drive, turn off console, unplug power supply, wait 10 or 20 seconds, then reconnect power supply and try again.
If that fails, assumeing other disks will read, your disk may have a major flaw. You can check with your local game store, they often have a machine that may restore your disk, (most places that I know of charge like 1 or 2 $).
Mar 10, 2010 | Microsoft Xbox 360 Console
My xbox won't read disk, nothing is wrong with the disks.
The reason that this happens is because the sensors on the back of the DVD drive have overheated.
When you overheat the Xbox it realligns the motherboard and the soldering gets supple again and will work for a little while, however this will not be permanent.
You will need to send it in to get it fixed or you can fix it yourself using a proven Xbox 360 Repair guide
Nov 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 will not read any disk anymore
My xbox will not read the disk. It starts to stops and saya open tray. I open it and close it and the same thing happens. I cleaned and nothing. I am in iraqi though but i kep it real clean can u help me. please
Jul 17, 2009 | Microsoft Xbox 360 Console
Games wont play. Problems with Disk player
it might be the disk drive lens just inst reading. if you still have warrenty with microsoft call and tell them whats wrong. if not then it will be cheaper if you buy a new disk drive for your xbox 360 and have a game repair shop replace it or just take it to the game repair shop and they can tell you whats wrong for sure. but call microsoft first you have 3 year warrenty with microsoft depending around what time you purchesed your system.
May 31, 2009 | Microsoft Xbox 360 Console
XBox 360 disc tray open
i have the same problem i called xbox and they said that it needs a new disk drive and it would be 100.00 so if you want it fixed youll nedd to call 18004myxbox and they will give you all the info on were to send it or for 100.00 more you can buy a new one like i did
Apr 28, 2009 | Microsoft Xbox 360 Arcade
I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Mar 28, 2009 | Microsoft XBOX 360 ARCADE Console
When i insert a disk and close it reopens and i close again
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys....
Nov 29, 2008 | Microsoft Xbox 360 Console
DISK DRIVE PROBLEM
Sounds like it is not reading the disk, make sure it is clean. Can you hear it trying to spin?
I hope you didn't push too ******* the door, you can make it jump a tooth on the loading gear making it go out of time. Check here for more solutions http://fix-your-xbox-360.blogspot.com/
Mar 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
