Screen shows "error" and a "1" followed by some spaces and another "1"
    President:
  • 2,712 Answers
What is the make and model of the TV please?
Posted on Nov 29, 2008
  • 1,879 Answers
Disconnect from the mains for at least an hour to clear/reset unit
  • 928 Answers
Your message did not seem to come through correctly. please retype Please provide the exact model of your Projection TV as well.
Also as a test try unplugging the TV for a few mins then plug it back in.
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Music player is showing 'not enough space "error.
Select "Restore all" from setting,but before you do this make backup all your important data like Contacts......If the problem still persist Click here1 and follow the instruction or contact mobile repairing Shop.Here is your 7210c file.Thanks for visiting fixya
Aug 08, 2011 | Nokia 7210
Lap top shows a screen saying "Computer is locked" just clicking on the box, makes it go to the next screen. just a hasle doing this every time.
In order to remove the lock screen after resuming from screen saver, sleep, standby, and hibernate, please follow these steps.
Windows Vista/7
1. Right click on an empty space on the desktop and select "Personalize"
2. On the far right of the Personalization window is the option for Screen Saver. Click "Screen Saver".
3. Unselect "On resume, display logon screen".
4. Click "Change Power Settings".
5. Click "Require a password on wakeup" on the left hand pane.
6. Select "Don't require a password" and select Save changes.
Windows XP
1. Right click on an empty space on the desktop and select "Properties"
2. Select the Screen Saver tab.
3. Unselect "On resume, display Welcome screen" or "On resume, password protect".
4. Select "Power".
5. Select the "Advanced" tab.
6. Uncheck "Prompt for password when computer resumes from standby". Click Apply, then OK, and then OK again.
Good luck, please post back if you have any difficulties, and thanks for using FixYa.
Apr 11, 2011 | Computers & Internet
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Tip
NOKIA-THE REBOOT TRICK
<p>This should work on all software versions of the 6110.<br /> <p>1. Go to the Calendar (Menu-8)<br /> <p>2. Make a note or reminder.<br /> <p>3. Enter some text into the edit box.<br /> <p>4. Hold "Clear" until the whole text is cleared, then press "Back".<br /> <p>5. Press "0". The main screen will now be showing but a space appears on the screen. (you can't see it)<br /> <p>6. Enter 4 digits (e.g. 1234).<br /> <p>7. Use the down arrow to move the cursor to the left side of the numbers and the space (Down arrow twice).<br /> <p>8. Now enter 6 digits and press the call button.<br /> <p> <br /> <p>Wait for a few seconds, the screen should start to flash and reboots. It should alsowork on other menus like the "Profiles" menu.<br /> <p> <br />
on Jul 27, 2011 | Cell Phones
My phone is showing blue screen with "error fatal
1. remove the battery and power cable 2. remove the sim and memory card 3. reinstall eveything 4. estart your system
Jan 28, 2011 | LG Vu CU920 Cellular Phone
Tip
Boost your computer performance
<p><span> <p>Your computer's performance mainly depends on the "Processor" and "RAM" availability. I am sure that whatever computer you have is capable enough to run your normal daily tasks smoothly. It should not stuck or freeze while checking emails, writing documents, watching movies or songs, printing or doing business online. These are some very basic tasks and require minimum resources to execute. Any computer with a normal system configuration should work them out easily, but we still face sluggish performance or freezing up while doing these tasks.<br /> <p> The reason behind this is the processor and memory status of your computer at that time. You can check the real time status from "Task manager" which you can pull up by pressing "Ctrl + Shift + Esc" key on keyboard. Following steps would optimize the processor and memory uses of your computer and make it more efficient:<br /> <p><br /> <p>&middot; Check running processes at background:<br /> <p>Every application we use has several processes running in background to make it work. Sometimes we are not even aware of the extra unwanted software or applications which start automatically and keep running in background and eat up our processor and memory usage. This you can check by Task manager's "processes" list. Also some of these applications show their notification icons in "system tray" area which is where you see the system time on your desktop. Try to keep minimum application running in background and this will make our system smooth as it will have more resources to utilize.<br /> <p>Follow the below steps to disable unwanted applications:<br /> <p>1. Click on "start", click on "run" or press "Flag key + R" from keyboard. Type" msconfig" on the "run" window and hit "enter".<br /> <p>2. This should bring "system configuration utility" windows on screen.<br /> <p>3. Click on the "startup" TAB on the top menu. This tab holds all applications which start automatically when you turn on your computer.<br /> <p>4. Check the list carefully and uncheck the ones you don't need.<br /> <p>5. If you are not sure about some application, type its name in google search, figure out its use and decide to whether you want to keep it running or disable it.<br /> <p>6. Once you are done with the List, click on "Services "tab on top.<br /> <p>7. This "services" tab holds all important programs which give a platform for other software to work.<br /> <p>8. Check the box in bottom which says "Hide all Microsoft services".<br /> <p>9. Now you have the list of non-Microsoft programs running in background. Some of these might be you antivirus software, backup software or messengers and others may be unwanted ones.<br /> <p>10. Identify the not required items and uncheck them.<br /> <p>11. Click on "Apply" and then "OK".'<br /> <p>12. It might give you a windows asking for "restart computer" or "Exit without restart ".<br /> <p>13. Choose "Exit without restart"<br /> <p>14. Close all other windows make sure none of you important files are open and then restart your computer.<br /> <p>15. If later you want to enable any services back, just follow the same process and "Check" them in the list.<br /> <p> <br /> <p>&middot; Keep track of free disk space on root drive:<br /> <p>Free space on root drive (mostly c :\) is very important as this space is used for virtual memory or paging, hibernation and other system requirements. Ensure that at least 3 - 5 GB space should be available on root drive. If you have less than this, delete some temporary or junk files from "temp" and "%temp%" folders.<br /></span><br />
on Jul 19, 2011 | Computers & Internet
Tip
Mobile Phone Tips & Tricks:
<p><b>THE REBOOT TRICK</b><br /> <p>This should work on all software versions of the 6110.<br /> <p>1. Go to the Calendar (Menu-8)<br /> <p>2. Make a note or reminder.<br /> <p>3. Enter some text into the edit box.<br /> <p>4. Hold "Clear" until the whole text is cleared, then press "Back".<br /> <p>5. Press "0". The main screen will now be showing but a space appears on the screen. (you can't see it)<br /> <p>6. Enter 4 digits (e.g. 1234).<br /> <p>7. Use the down arrow to move the cursor to the left side of the numbers and the space (Down arrow twice).<br /> <p>8. Now enter 6 digits and press the call button.<br /> <p> <br /> <p>Wait for a few seconds, the screen should start to flash and reboots. It should alsowork on other menus like the "Profiles" menu
on Jan 30, 2011 | Cell Phones
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
