Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Louding sparking in the back panel.
The television will work fine for about 30 minutes. Then after a while it will start popping and sparking in the far back bottom right corner. Turning the TV off will not fix it, you have to completely unplug it. If you leave it alone for couple of hours or the a whole day it will work for another 30 minutes. Im not sure but I think it is charging a capacitor and then discharging. Capacitor plates might be really close and arcing across or dust might be in there messing with the electronics.
  • RCA Master
  • 8,617 Answers
More likely its the flyback arcing which is a common problem with the ITC222 chassis which is what your model is. You can get replacement 259296 flybacks at the following link with free detailed instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on Nov 30, 2008
TX-52F480S lines
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Oct 11, 2012 | Westinghouse TX-52F480S 52 in. LCD TV
The screen blanks out after approximately 20 minutes.
The power supply board is dead.Those high voltage transformers on the power supply board,one those power coil have a short in it,that why it cause this shutdown a have a loud electrical current noises.Tries websites like Shopjimmy.com.Ebay.com to buy a new refurbish power supply board for the replacement,should solved this loud electrical noises shutdown to tv.
Jul 10, 2010 | Sony BRAVIA KDL-40V3000 Television
No picture after loud pop. Sound works fine
i have the same fault loud pop and no picture but sound is ok
Oct 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Loud popping noise and spark coming from red projector
I would guess you have a High Voltage Leak at the Anode Lead Cap where it Mounts to the CRT. This is not a area to mess with You are better off calling a professional to fix it. It may be a little difficult to confirm if it is a intermittent problem.
Hope this helps,
Skyassoc
Jul 04, 2009 | Hitachi 51F59 51" HDTV Projection...
Loud pop then picture goes away.
bad upper, lower y sus & z sus pcb about 800 to 1000 to fix
Jun 05, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
On one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
May 18, 2009 | Sylvania Televison & Video
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
TV not working
need mor info the tv when turn on after 15 or 30 minuts works fine ?
Mar 21, 2008 | Pioneer PRO-520HD 53" Rear Projection...
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
