Question about Liebherr Refrigerators
I have just purchased a Liebherr pull out larder fridge to replace the one I already had, I am having problems getting the door seal to stay in place at the top of the fridge. When I push it closed firmy, the seal touches the metal surround of the fridge but as soon as I let go the top of the fridge door pulls away from the actual fridge by about 1 cm thus allowing warm air into the fridge. It was a really expensive fridge but I chose it because I liked the pull out design-am now starting to regret it-Help!! What can I do-it's brand new but don't think it will last long if warm air continually getting into it- many thanks Jean
  • 121 Answers
The door may be twisted or the seal may need to be adjusted try a hair dryer on the seal it will heat it up and readdjust the seal-gasket
Posted on Nov 29, 2008
Replace seal on Liebherr french door
Are you talking about the center door gaskets? If so, Purchase new gaskets Left and Right (2 different part numbers) from Adco Service of Scottsdale AZ. The gaskets pull out from the two grooves and put liquid soap in the new gasket channel that holds the heater wire. Observe the channel where the wire came from.. Insert the heater wire slowly until it is at the end. Starting at the top, insert the gasket tongue that is towards the inside if the refrigerator first all the way down, then insert the side at the edge of the door. Be sure to firmly seat the gasket
Dec 23, 2013 | Liebherr CS2062 Bottom Freezer French Door...
Hi, we have had a liebherr KI 2444 intgrated fridge/freezer since new, 10 years ago and it has been very reliable. We have noticed an increasing build-up of water gatering on shelves and items, which is...
Most likely condensation caused by a faulty seal. I am in the UK, no idea where you are. Try looking up espares or another spares company in your country.
Apr 16, 2017 | Liebherr Refrigerators
Liebherr KBES 3650 - too warm in main fridge compartment. Hi the main fridge compartment of this larder fridge warmer the it should be (milk does not taste as cold as it should). The temp...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Liebherr KBES3650 Stainless Steel...
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
Bosch larder fridge door pops open
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 19, 2009 | Refrigerators
Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Sep 23, 2008 | Liebherr Refrigerators
Beco larder fridge - excess of water in drip tray at rear - fridge cold but items in fridge are heavily condensed
you have air leaking into the fridge. check door seal by trapping a slip of paper between seal and cabinet all way round
Sep 17, 2008 | Refrigerators
Refrigerators Logo
488 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
