Question about LG Refrigerators
Error message on refrigerator - LG Refrigerators
    Sergeant:
  • 291 Answers
What is the exact model number.and what is the error message.tell me.
Posted on Nov 29, 2008
  • 121 Answers
Http://www.repairclinic.com/0078.asp you will find the codes hear
What does error code 22 e mean?
It's a refrigerator fan error. Click on link then click onto the 22E Error=> Error Codes Messages Blinking
Appliance 911 Sea Breeze
Dec 06, 2015 | Samsung RF263BEAESR
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
I'M GETTING ERROR MESSAGE "ER IF"
Form what I have read up on it appears that the only fix is the mother board. It is not communicating properley and needs to be replaced. Good luck
Sep 09, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
Kenmore trio Refrigerator (bought 9/1/07)quit running message bar inside refrigerator read error. I shut off power waited a minute or so turned power back on seems to be running. What could have caused the...
sounds like its a sticky thermostat and the fridge started to warn up to much,,, the compressor was not told to start up so up come the error message,, it could work out ok now but dont hold you breth,,,
Oct 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error message ER FF - refrigerator is not cooling as a result
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
LG refrigerator error message ER IF
ok if unit is under 1 year old call a tech because you might need a new motor fan and new main board . make sure you out let is properly grounded
Jun 30, 2008 | LG LFX25960ST Stainless Steel French Door...
Error message er if
Hi. Error FF is your Fresh Food Fan. Otherwords, the evaporator fan motor has failed. You should replace the motor and motherboard. You may get by just replacing the motor. Sears doesn't manufacture the refrigerator. They just pay extra to have Kenmore put on it. Its the manufacturer that needs to back their equipment. If you bought it from Lowes, you can't hold Lowes responsible for the ongoing issue. They sell the same refrigerator. Anytime this model refrigerator displays an Error code, unplug it for 5 miniutes and replug it. Sometimes it was a computer misfuction. Good luck! Mack
Dec 28, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Error Message ER FF
The refrigerator has noticed the freezer fan is not responding. Need to replace the fan motor. Also called evaporator fan motor.
Oct 09, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
107 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
