Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The machine produces noise when it comes to dry
It sounds like a loosen belt
  • 121 Answers
Sorry it it dose not have a belt but it may have something in the pump
Posted on Nov 29, 2008
Noise at the end of spin as it stops.
he5t kenmore elite. i have noise coming out as it begins to was with a load in it if it spins fast no noise. when it spins slow i get noise. i thought it was the rear bearing but not in my case. it ended up being the belt was very dry, i spray wd40 on all over the belt, now noise is gone day saved.
Jan 23, 2014 | Washing Machines
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
Rattles when drying
I need more details but typically a dryer will make a rhythmic rattling noise when loose change and other small metallic objects as well as buttons become trapped in the tumbler impellers (those wing shaped things in dryers).
Loosen and remove the top of your dryer.
Rotate your drum, taking care not to rotate it the wrong way. The right direction of rotation will produce friction to the belt, the wrong direction will cause slack on the belt on one side or the other of the drum.
Rotate the drum until the back side of the impeller is directly on top with the outer screws facing you at the top of the dryer. Remove the screws and pull out the impeller and you will find your noise makers. Do this with the remaining impellers and reinstall.
Mar 05, 2010 | Dryers
Loud grinding noise when spinning. So I layed the machine down on its front to work on it. I loosened the belt, and then removed the lint catcher pump. I cleaned the pump by flushing and reverse flushing...
Just so you know, in the first place, (NEVER PLACE A WASHING MACHINE IN ANY POSITION BUT UPRIGHT. That's just asking for a leaking gearcase (transmission)! Your best bet is to call a technician. It sounds more like stress on the drivetrain from the water weight! The only way to tell would be to pull the case off to observe the tub as the water fills to see if the tub is indeed pusing downward!
Dec 16, 2009 | Maytag Performa PAV2200
DVD PLAYER FAN MAKES REALLY LOUD NOISE IT SOMETIMES GOES AWAY WHEN I TAP THE BACK OF THE FAN SOUNDS LIKE ITS JAMMING
When fan's shaft got dry, it start vibration in spinning and produce lound noise. Lubricate exhaust fan shaft with good quality machine oil.
Thanks.
Nov 18, 2009 | Samsung HT-Z310T Theater System
I wana fix the whistling sound coming from the serpintine belt
you probably have a dry bearing, or the bearing is losing its lubrication. Make sure that the sound that you are hearing isn't normal belt noise.
Repairs can be done by yourself. Remove the belt, remove the idler pulley, and take to local bearing shop / machine shop / automotive shop to have new bearing installed.
Jun 05, 2009 | 1983 Chevrolet Chevy
I have a Kenmore 30 Stitch, model 385.1884180 serial #21105527-it has started making a grinding noise when using stretch stitch choices. I have cleaned the machine. But the sound comes from inside the arm,...
easy fix... same thing happened to me. take the back part off by the on and off switch and you'll see the loose belt. loosen the single screw next to the smallest pully and adjust tension.
Apr 15, 2009 | Kenmore Sewing Machines
Whistling soung from engine
Take a look at the belt see if it has cracks or worn grooves.. if it dose have it replaced. if it doesn't pull on the belt back and forth see if the tension pully is giving the belt tension( it supposed to be about 1/2 of an inche to an inch or try to turn the belt around to almost half way) if not replace the tensioner pully. if good check the free pully by starting the car and spary a bit of wd40 on the center of the pully if noise disappers replace the free pully. if not see ur local auto shop..
Aug 20, 2008 | 2001 Land Rover Discovery Series II
How can i fix this problem ??
Turn the transfer belt by hand to check for any binding or noises. It could also be the fuser rollers causing the noise due to bad bearings since it sits above the transfer belt when it it closed into the machine.
Do you know how to remove the transfer belt to check?
Aug 19, 2008 | Ricoh Aficio 1035 Copier
My Bosch Nexxt Essence front load washer is making a knocking and squeaking noise during the whole spin cycle. It sounds like it's coming from the drum mounts - what should we do?
My Bosch Nexxt Essence front load washer will not drain. I changed the lint filter, and insured that the drainage hose was free of debris. I removed all the wet clothes, wrung out the excess water, and redistributed the clothes. Still, no draining or spinning. Initially there was a humming sound, but now there is no sound at all when I try to restart the drain or spin cycles. All the lights are appropriately "on".
Apr 13, 2008 | Bosch Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
15 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
