Question about Whirlpool Duet GHW9150P Front Load Washer
My mother just got a brand new Whirlpool Duet Sport washer. In the middle of the cycle is delayed the cycle and opened the door thinking it was like her old top loading washer. However, now we cannot get the washer to start. The controls are working but it won't turn on. What can we do?
  • elizabeth810 Dec 01, 2008
    F 1 Error after son opened before the cycle was complete. I have unplugged for over an hour and it will not reset! Please help. Been on hold with whirlpool for over an hour now and the sales center I bought the machine from has NO idea what to do!
    President:
  • 1,294 Answers
Your door switch may have got damaged, you have to replace. Can do it yourself. Sites for spares:
RepairClinic.com (which is gud)
AppliancePartsPros.com
espares.co.uk
Posted on Mar 11, 2009
  • 121 Answers
Un plug it for 5min and it will reset
Posted on Nov 29, 2008
    Sergeant:
  • 291 Answers
Unplug the machine for some time then again replug it and check out.it gets resetted mostly and starts working.
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
My washer is locked. I unplugged and plugged bach
holding the end of cycle button is the control lock,not the door lock. Check to be sure that the control lock light is off--if not, hold end of cycle button again till control lock light goes off.
I've given up on the door lock after a few years fighting it, and researching. There is a solution on fix-it that may work--if it is computer(mother board I think they call it)--and not door lock mechanism. I've read many posts from duet owners that replaced door lock mechanism just to have it be a soldering problem with the "mother-board" that makes the machine "think" there is a door lock failure.
Here is link to a fix-it post I used today to get my machine open and retrive clothes it has held hostage for several days:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error Code F11
TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Very Loud and Active Whirlpool Duet Sport Washer
It looks like the transit bolts are still in there at the back and if you take them out it should be more quiet.
Dec 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
114 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
