Computers & Internet Logo
Anonymous Posted on Jun 08, 2012
Flip the screen - Computers & Internet
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Jun 08, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1059856
Points
15385
Flipping the screen is part of the Display in the Control Panel. You have to go to the Settings tab then click Advanced and look for Rotation.
Click Start/Control Panel or Start/Settings/Control Panel then look for Display or Appearance and Personalization. Open the Display then click Settings/Advanced/Rotation.
I have a dual flip out screen and the screen went completely black when I was driving. Now the screen won't turn on and it's still flipped out.
Flip outs are generally very fragile due to the nature of the hinges and cables used in the screen and main unit. The only thing I would recommend is to trash the flip out and put a full double din or a standard single din radio.
Oct 28, 2014 • Cell Phones
What is the mobile number of this rim number (8991211460000908890) please send me query immidietly...
you need the imei # of the phone the rim # just lets people know exactaly whats in the phone example
81xx - Suretype, Non Flip, Camera
82xx - Suretype, Flip, Camera
83xx - QWERTY, Non Flip, Camera
85xx - QWERTY, Non Flip, Camera, Expanded Internal Memory
88xx - QWERTY, Non Flip, No Camera, GPS, GSM
89xx - QWERTY, Non Flip, Camera, High Res Screen, Expanded Internal Memory
90xx - QWERTY, Non Flip, GPS, Camera, High Res Screen, Expanded Internal Memory, 3G, WiFi, Video Recording
95xx - Touch Screen, Non Flip, GPS, Camera, High Res Screen, Expanded Internal Memory, Video Recording, GSM, 3G
96xx - QWERTY, Non Flip, Camera, High Res Screen, Expanded Internal Memory, GSM, 3G
And now the last 2 digits
xx00 - Base Model, No modifications
xx10 - GPS, GSM, Video recording
xx20 - WiFi, GSM, Video Recording
xx30 - CDMA, EVDO, Video Recording, GPS
xx50 - CDMA, EVDO, Video Recording, WiFi, GPS
the phone you got for example would be a "Non Flip, Camera, High Res Screen, Expanded Internal Memory" the other numbers in the rim also tell more about the phone. but a persons phone # can not be found using this #
Oct 06, 2010 • Cell Phones
I cracked the screen on my flip screen and it doesn't display anymore. Can I replace the flip screen.
Question is, can you?
Motrola flip phones are tricky especially when replacing the flex cable or flip.
Let the experts do the job for you.
either call Motorola or go to a local repair shop.
1helpful
Flip Video Mino keeps freezing up, can't shut down or upload
At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
2answers
Both screens on my bb 8220 flip phone do not work phone still works though
check the connection between mother board and the screen.Its a flex/ribbon cut-not working anymore.better to replace a new flex/ribbon for you Flip BB.
1helpful
5answers
Broken screen on Blackberry 8220 Pearl Flip
If you're tech savy you can use a blackberry repair guide that will show you how to disassemble it step by step and replace the screen, the screen is available on Ebay or you can go to the repair service.
External display on pearl 8220 cracked
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Check out the guide I wrote for replacing the blackberry flip LCD display screen. There are also links to by the new pearl flip LCD screens
Blackberry Flip 8220 LCD screen Replacement Guide
Screen keeps flipping around
Re-install the software used to flip screen...
6helpful
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
2answers
Lcd won't work when it is flipped and facing out in the back.
The flex strip is cut and thats why you are facing that problem ... please use it the way it works till you can ,,,,, when it completely goes dead have it replaced by a repairman ....
Grand Canyon Tech
Grand Canyon Tech
