Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Ge pdw7880j10ss dishwasher lower roller fell off and melted on lower heating element. need to know part number of lower roller and plastic clip that affixes the lower roller to lower rack?
  • mollard Mar 14, 2009
    Every stinking one of those lower rollers will not stay on!! GE wants $8 apiece for those 25 cent items x6 that's almost $50. Will the new ones stay on??
  • R Mader Dec 25, 2012
    Mine keep falling off also, every time you roll the rack in or out the wheels fall off. I wrapped thick rubberbands around all the wheel mounts. it's a clumsy solution, but cheaper than new wheels.
    Scholar:
  • 131 Answers
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
One of the thick plastic severing spoons apparently fell to bottom of washer, it has melted on to the heater part, how do I get this utensil off if the heater.
your best bet is simply to unplug it and break it off carefully then use steel wool to clean up the heating element of the remaining plastic. if need be and there is no danger of melting anything else you can use a pen torch to heat up and hard to remove plastic and wipe it away with a cotton clothe or scrap of denim some fabric that wont melt.
Sep 25, 2017 | Dishwashers
A plastic lid fell to the bottom of my disher and melted, how should we get it off?
Remove the bottom drawer from the dishwasher. Remove the lower spray arm to get it out of the way. Slide a sheet of polyethylene (plastic bag material) under the heater and over the pump to catch any trash that you don't want to go through the pump. Using a metal-cutting snips (scissors for cutting sheet metal) for rigid plastic or heavy scissors for flexible plastic, cut as much of the ruined plastic lid away from the heater element as possible. Be very careful not to nick the heater element, and brace the heater element and lid with one hand while you cut to prevent mechanical stress on the heater.
You may be able to use a diagonal wire cutter to snip most of the remaining plastic off of the heater element. A rasp may also work, but be especially careful not to go into the heater with it.
If the plastic is fairly flexible, you may be able to simply peel it off. If the plastic is burned on, you can try scrubbing it off with Scotch-Brite.
If you are really impatient and a gambler, you can try setting the dishwasher to plate warm for a few seconds to see if it will soften the plastic just enough so you can pull it off directly. There is a risk you will create a bigger mess, but it may be faster. The worst that can happen (besides a fire if you heat it too long) is you will need a new heater element.
Jan 22, 2011 | GE Nautilus 24" Built-in Dishwasher
I a Westinghouse dishwasher 920 and a plastic spoon fell onto the element while it was on and its melted the spoon on the heat element and i cant remove it. how do i replace the element i am a motor mech...
Break as much of the plastic off as you can and just let the rest melt off or melt it with a solder gun . won't hurt anything. If you want is easy to replace just hall machine from hole and tilt back remove the wires and the nuts holding it on .
Dec 03, 2010 | Westinghouse Dishwashers
I have a six year old dishwasher that started leaking water out of where the heating element is attached on the lower part of the unit. It appears as though the heating element has melted through the...
dont use it!!!!!!!! ring the manufacturer with the serial number ect phone number should be on appliance booklet or get it from a dealer
Jun 06, 2009 | Dishwashers
Plastic melted on Dishwasher heating element
youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
Dec 01, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE PDW9700 - Heating Element turns on by itself and Burns my dishes
have experienced this problem on some zanussi machines. what is happening is that the machine continues thro cycle thinking there is water in machine when there is not. can be caused by:
slow pump rate caused by blockage especially near the drain pump inlet
faulty pressure stat
Aug 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
A child's plastic cup top melted on heating element. . .how to remove residue
Gently scrape with a razor blade or paint scraper to remove the large pieces, then use some emery paper or very fine sand paper to remove the rest. Use care when applying any pressure on the element, and try not to leave any gouges in the element surface. I have also had good luck with a nail file. Hope this helps you.
Feb 01, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
1,028 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
