Hi when I turn on my Panasonic DMR-EZ45VEBS I get an error that states 'LD FVU' then the CD slot ejects. It them simply doesnt allow me to do anything. Has anyone experienced this? If so can you help fix it? Thank you Andrew
I get exactly the same problem with my Panasonic EZ48 recorder.
It also displays FM List DL error .It sometimes sorts itself out by holding the on switch for 20 seconds.
Ian
Posted on Apr 03, 2010
U99 error code
The remote isnot going to eject the the disc, You have to press the eject button on the unit, To get the disc to eject,
Nov 26, 2012 | Panasonic Dmr-eh67e Pal Dvd Recorder With...
I would like to download the English version of the manual (PDF) for the Panasonic DMR-EZ 45V Video/DVD recorder combo
The manual is available from Panasonic: http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239 . When I fill in the DMR-EZ45V, I got manuals for the DMR-EZ45VEB and DMR-EZ45VEBS.
Additional models are available from the Panasonic UK support site.
I hope this helps.
Jan 04, 2011 | Televison & Video
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I unlock my panasonic DMR-EZ45VEBS to play all region films
You need to buy a service remote to do this on your model, but the official service remote costs more than the player and is not sold to the general public.
Alternatively, you can rent a chipped regular remote control which does the same job.
In the UK you can get them from www.multi-region.co.uk
Note that on your model there is no other way to hack the player, it can only be done using the correct remote control.
The remote chips are available separately but are not easy to fit unless you're an experienced electronics technician; you can buy read-chipped remotes but they typically cost the dame as the original player.
I hope that you have found my reply to be of use and only ask in return that you rate my answer.
Nov 08, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
May 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Error code u61 will not clear, unable to reset the DMR-EZ45VEBS
Hi, there was no solution to my problem with the error code U61, having talked to a Panasonic repair center it would cost £180.00 to fix this unit as the board and DVD recorder have to be replaced as one unit. It would cost me around £160.00 to buy a new one so there was no point in having it repaired.
Aug 04, 2008 | Panasonic Televison & Video
Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
ERROR MESSAGE.....
had the same LD FVU (Load FVU or firmware disc) message and fixed it this way: download firmware from http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP and make firmware disc and insert. After it loads and updates, you need to activate your remote again. When the message SET 1 appears, on the remote press ENTER and 1 together for 10 seconds. Done.
Jun 24, 2008 | Panasonic DMRES15 DVD Recorder
DVD does not start set up automatically
Hi Turtis,
Did you ever solve this?? I have a similar problem on my DMREZ25EB and got told it could be resolved by updating the firmware which is what the FVU is meant to mean. However, I can't find my version of the Firmware on the panasonic.com site. If you solved this could you let me know what you did.
Thanks,
Vee.
Aug 23, 2007 | Panasonic DMRES15 DVD Recorder
Televison & Video Logo
691 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
