ERROR 305: 69
VAIO VGN-NS190j WHEN I TRY TO MAKE A RESTORE COMPLETE SYSTEM WITH DISK, IT HAPPENS ERROR 305:69
    Top Expert:
  • 5,032 Answers
Most times the Recovery from cd's don't work. You'll be better served by doing a Reinstall of Windows.
System Recovery (sometimes referred to as Factory Restore) will set your system back to when you first purchased it. It Deletes Everything. Most times the System Recovery does not work unless there is a recovery partition on your hard drive created by the manufacturer. If you are trying to recover from a set of cd's most times it does not work.
Instead of doing a System Recovery it's much easier to just Reinstall Windows. Look on your computer for the Certificate of Authentication (COA) Sticker. It will tell you what operating system is on your computer and it will give you the Product Key Code (a series of 5 letters and numbers) that you will need to activate windows. If you don't have an operating system disk, borrow one from a neighbor, friend, relative or co-worker. Just make sure it is the same as your COA Sticker's operating system or it will never activate. Also make sure you get the COA Product Key Code for the disk you borrow because sometimes the system will ask for the one that is on your system and sometimes it will ask for the one from the installation disk.
Posted on Jun 08, 2012
DJGray
  • 56 Answers
SOURCE: restoring operating system for Vaio VGN-S460
Not necessarily. Formatting the hard drive will only wipe the data on the partition being formatted. The restore partition, if it exists, will still be there.
I have read that the restore partition can be accessed by pressing F10 at startup. As I don't own this sony machine, I can't verify that.
Posted on Mar 04, 2009
  • 148 Answers
SOURCE: Can't restore factory intallations and settings: Vaio VGN-FE880E
Are you doing DESTRUCTIVE recoveries or are you doing NONDESTRUCTIVE recoveries? Try another hard drive in the machine and recover to that. Nondestructive recoveries replace the operating system without destroying the personal data. Its possible the original problem is propagating over to the recovered systems. Do a destructive recovery. Understand any data not backed up will be destroyed. Possible the original problem was a trojan virus.
Posted on Mar 23, 2009
micromend
  • 748 Answers
SOURCE: Sony Vaio VGN-NR498E recovery disk
Hello
Well, the recovery disks won't allow you to go to your present system. The recovery disks are designed to put everything back the way it was when you bought the computer, minus all your applications and data. If it's your data that you need then a reputable repair service like mine can slave your hard drive to another system and recover all your data (not applications), provided the hard drive has not electronically or mechanically malfunctioned. Again, a reputable repair person can tell you the status of the hard drive.
Thanks
Posted on Jan 07, 2010
SOURCE: I need VAIO® VGN-FJ170/B Restore Disks
You can create your own disc from the Vaio recovery center.
If the computer is no longer booting up and the Vaio Recovery center is no longer accessible, you can call sony parts center to check if you can buy a recovery disc for your unit
parts center 8004887669
Posted on Apr 11, 2010
SOURCE: recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
Posted on May 18, 2010
No audio on VGN-FE780G, symbols indicate everything is fine
right klik on system tray bottom right on ur screen on the speaker icon ,
left klik on playback devices
make ur speaker icon the default player,
done,
Mar 29, 2017 | Sony VAIO VGN-FE780G Notebook
System recovery
Try holding alt + F10 at boot. See if this starts the factory restore process.
Jun 14, 2013 | Sony VAIO VGN-NS190J/L 15.4-Inch Notebook...
Sony vaio vgn-fw290
Did the Restore complete? If not try it again.
If the Restore completed and when you boot the machine all you are getting is a black screen with a blink cursor try the steps below:
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 16, 2012 | Sony VAIO FW Series Notebook PC...
I am trying to restore to the original state with the three recovery disks my Vaio VGN-NW350F but it first showed an error 320 and then an error 330. Afterwards I cannot even run the program to restore...
1. For Error 320 or 330 , if possible, run the RAM hardware diagnostics to determine if the RAM has failed.
2. Disconnect all external hardware that is attached to the computer.
3. Reset the BIOS to the factory defaults.
4. If the RAM passes the test, only the HDD requires service.
This error also may occur if you are performing a system recovery on a new unformatted hard drive or if sector 0 of the hard drive was cleaned.
Select the "Restore Complete System" option from teh recovery discs and during the installation wizard choose YES for the option "Do you want to keep the factory default hard drive size?".
Jan 25, 2011 | Sony VAIO VGN-NR498E/S Notebook PC
VAIO VGN-FS742/W PC Notebook: i need to know how to restore factory settings wit...
This Computer has Recovery Partition hidden in the Hard Drive. You can access the Recovery Partition using the VAIO Recovery Wizard or pressing the F10 Key while restarting the Computer.
The System Recovery will restore the Computer back to the factory defaults and all the data in the Computer will be lost.
  1. To access the VAIO Recovery Wizard, please click "Start", All Programs" , VAIO Recovery and VAIO Recovery icon.
  2. Then, in the VAIO Recovery Window, please select the "Restore C: Drive" option.
  3. Then, in the Restore C: Drive window, click to select the I understand box.
  4. Then, click the Next button.
  5. After the bundled applications are installed, under Restore C: Drive (Step 4 of 4) , click the Finish button.
  6. The computer will restart and the operating system setup wizard will begin.
  7. Please follow the on-screen instructions to complete the setup wizard.
Good luck..
Thanks for using Fixya.
May 18, 2010 | Sony VAIO VGN-FS742/W Notebook
Where can i down load restore complete system disk ???
you have to call the manufacter and request a request disk for your laptop. Tey usaully cost beetween 25 to 30$
Jul 20, 2009 | Sony VAIO VGN-FJ270/B Notebook
Describe your Sony VAIO NS Series Notebook PC VGmy sony ns asked to restart yesterday to uninstal zango after i installed it the previous day. now, it tells me i have disk errors, but they are never...
Sounds to me like your hard drive is going bad if disk errors are starting to be reported.
Try restoring the laptop back to factory defaults. Reason for this is because if your hard drive is good and your operating system is corrupt then this would fix the problem with the OS.
If your hard drive is bad then it won't restore back to factory defaults cause it will error out on you and you'll know at that point that the hard drive is bad cause it has bad sectors on it that it cant write to.
Jul 08, 2009 | Sony VAIO NS Series Notebook
Tv turner not working in sony vaio VGN-AX570G
I have to ask this question, due to people posting in wrong categorys.
Is This A Sony-Vaio VGN-AX570G Laptop Computer, your struggling to find drivers for ?
All Vaios Come With Restore Disks. If you have these i,d suggest doing a system restore, whereby all of your original Vaio Software will be repaired-replaced on your hard-drive.
If you don,t have the Vaio Restore Disks, you can purchase on-E-bay for About £15.00.
No help on Vaios support Site For That Actual Model.
Mike @ Compurepair.
Mar 04, 2008 | Computers & Internet
Computers & Internet Logo
562 people viewed this question
David Payne
David Payne
