There's a tiny red light in the corner of the camera, and i don't know if it has anything to do with the problem but the screen appears to turn on but it doesn't show anything. if i plug the camera into the computer i can still see all of the pictures on the camera.
SOURCE: Download pictures from my Rebel EOS to my computer
Take a look at Picasa, from Google. Also take a look at Irfanview. I haven't used Irfanview in over a year (since I moved from a PC to a Mac - it's the one piece of software I really miss on my Mac), but before I moved to the Mac it was my primary photo organizer and viewer. It's a very impressive program for free software from an individual programmer (Irfan).
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
SOURCE: Canon Digital Rebel XT / EOS
In the communications option of the camera Menu, there are two options to choose from. Try changing the options. one of them works with Canon software to download images.
SOURCE: Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
SOURCE: I am missing my installation cd for my Canon EOS
go to this page, confirm it is taking you to the windows 7 version. previous versions of windows, like Vista, will probably not allow you to transfer photos without first loading this utility.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=16303#DownloadDetailAct
