Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Dishwasher will not run. clean light flashes seven times
The green light above the clean button flashes seven times and the dishwasher will not start. i have checked the water supply and if the float was stuck, both were ok. the diswasher was full when it failed. it filled with water and began it's cycle then shut down. the only feature that still works is the drain cycle when the drain button is pushed. how do i reset the dishwasher.
  • evryknee Mar 04, 2009
    have to restart our Kenmore dishwasher over and over.
I tried the button sequence described by guest #1 but nothing happened.... is there anything more to it?
Posted on Jun 13, 2009
  • jaredmac Jun 13, 2009
    NOTE! The correct reset sequence for the DU1055XTP is "Hi-Temp Wash, Heated Dry, Hi-Temp Wash, Heated Dry".
This worked!! Thank you, we were ready to buy another dishwasher and you saved us around $400.00...
Thank you, thank you, thank you!
Posted on Mar 30, 2008
TURN off the electricity supply.Remove the left hand panel and see the wiring on the plastic water chamber(Two black wires to a blue connection on a cicuit board) Clean this connection. Replace the side.Turn electricity supply on. Hold down the start button till it resets. Job done.
Posted on Feb 14, 2007
I had success with the "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine. The process runs for about 19 min. and shuts off. During the process several LED's light up and several funtions start and stop. If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. Thats all I have done and the wife is no longer on the war path. Good Luck
Posted on Mar 01, 2007
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Green clean light is flashing, it will not clear and will not run because green light is flashing
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Jun 08, 2011 | Dishwashers
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
676 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
