Question about HP Pavilion dv4000 Notebook
I REPLACED MY HD, installed agian XP OS...
SO now i have my old HD in a USB box, so i can access my data..
Problem i still have a few important softwares installed on this USB HD.
So i would like to boot from the old OS still installed on my usb HD when i want to run these softwares, without having to install them all over again on my new HD or unplug my new HD and plug back my old one!!
Can you help? THKS A LOT;
  • 2,110 Answers
Yes U can enable Boot from USB device ...& first boot device must be USB Hard Disk...
Posted on Nov 29, 2008
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
I have 3 partitions on my HD, 50(C),50(E) & 350 (F)
Henery, you should be able to hit the ESC key while booting up and give you the OS choise.
Dec 28, 2009 | Computers & Internet
P5rd1-vm sata installed xp nit detect
Check in the BIOS settings. You probably want to either enable legacy AHCI support, or you need the appropriate AHCI/SATA drivers for Windows XP. Otherwise, the system will install in compatibility mode, and then be unable to recognize the disk once booting in standard mode.
Also, verify that you have the latest BIOS installed:
Oct 27, 2009 | Intel ASUS P5RD1-VM ATI Radeon Xpress 200...
Dell latiyude C400
The system is in a reboot loop. Possible causes are:
Corrupt installation of Windows
Bad Hard Drive
Bad Motherboard.
Try booting to the Windows XP CD, see if you can access recovery console and run CHKDSK /R If that doesn't resolve, boot to the resource CD, and run diagnostics on the HDD
If you can't, boot to the XP CD or Resource CD, try removing the HDD and booting to the CD. If the system boots then, the HDD is most likely bad.
If you can't boot to any device, try RAM modules individually, see if system boots with only 1 module installed. If no change, then motherboard is bad. On a system this age, I do not recommend replacing a motherboard as it is not cost effective
Jun 22, 2009 | Dell Latitude C400 Notebook
Need floppy to boot in XP PRO on HD
Hi, if you can boot using xp cd then instead of going into recovery console you can elect to install xp. The cd will search for existing installations and offer to repair for you. If you are able to get this option it will not delete your programs or personal stuff. You will need your xp code and you may need to reactivate windows when finished. If it doesn't offer repair then f3 to exit so you don't overwrite your personal stuff.
Jun 07, 2009 | Microsoft Windows XP Professional
Is it possible to install 2nd 0/s on separate hard drive 40gb,id not sata attached via usb with laptop of dell inspiron 1525 c2d give steps to install
It depends what kind of SO do you want to install
I recommend you to user an USB Linux distro.
Anyway, normally when installing any SO lets you select the partition where you want to install the SO.
Select the partition belonging to the USB External HD, and do everything else normally.
You must have in mind that you will lose everything in the USB HD, and that using it this way the OS will work only when the HD is plugged to the same PC, it may work with a different PC with different hardware but the SO will install the new drivers for the new hardware.
That's why I recommend you to use linux, check this out
Mar 19, 2009 | Microsoft Windows 98 for PC
HD installed with XP in Giga MB,not booting up in the originalP3
it is impossible or else you reload the hd on the motherboard
Jan 21, 2009 | Computers & Internet
Bois problems????
No - this is something that can generally only be resolved with a repair install of the XP.
The repair option can be accessed while doing a standard (i.e. boot from the CD) install. Note: this is a repair option after you select to install; not the repair/recovery options on the first screen.
It should detect your OS and ask if you want to repair it. This will cause you to have to reactivate windows, and I highly recommend having your drivers already downloaded and ready to be installed. Some programs my have to be reinstalled also.
There is a sysprep tool that can be used, but I've always found it easiest to do a repair.
May 07, 2008 | Syntax SV400 Motherboard
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
How to Install a new HD on Dell Inspiron 6000?
You can always parition the drive, and install both Ubuntu and XP (dual boot).
Yes, you will be able to access the files (providing the drive isn't totally crashed), although Ubuntu may not "know" what the files are.
Jan 10, 2008 | Dell Inspiron 6000 Notebook
HP Pavilion dv4000 Notebook Logo
237 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
