Question about Toshiba 52HM95 52" HDTV Projection Television
No audio on one channel
I have no audio on a single HD channel with the cable card but it's there when we put a HD box on it. The analog channel has audio as well as the standard def digital channel. We tried a new cable card, same problem.
  • 505 Answers
I've seen simmilar problems with the toshiba cable card compatability.. however we could never solve (replacing all parts,etc). It is either the tuner of the television malfunctioning at a very specific frequency, a very specific interference, or a programming/software issue between toshiba and cable provider. The first is repairable with parts, the second two are not good. With either you'd have to keep complaining to the manufacturer and cable company, both of which will likely get you now where. They make more $ on that cable box..
Posted on Dec 06, 2008
How to tune samsung tv
Mono is the first point I am stuck on. Mono is an audio reference but I am going to assume that you are only receiving the analog channels and not the digital. If you are coming off of an antenna then the antenna has to be HD to receive HD channels over the air. If you are off of a cable box then this has to be dealt with from your provider. You will also need an HD ready TV or if you do not you will need an HD converter box to make your tv work with the digital signal.
Apr 02, 2014 | Televison & Video
Yamaha rx-v2500 receiver how to hook up speakers
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
I have a kenwood VR405. I am useing a samsung blu ray and a cox cable box. both components are running directly into the samsung flat screen via HDMI. I am backfeeding digital audio to the VR405 via...
Josh, define the 'backfeeding' of the digital audio from the two HD components into Video 1. Those are ANALOG inputs on the VR405. You have two coaxial- and one optical-digital audio input you could/should be using.
I'm surprised you're getting ANY audio (much less digital audio) from the BD and Cable Boxes unless you also have an analog audio path coming in from (what?) the TV.
Sep 29, 2011 | Kenwood VR-405 Receiver
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Televison & Video
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Vizio 22 inch HDTV--Loss of volume on non-HD channels only
Good evening! Go into your audio section of the Menu and make sure that SAP is off.....let me know how you did.
Apr 21, 2009 | Televison & Video
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
When you watch TV with a Cable Box or a Dish Network Box you are using a tuner inside that box. The signal that comes out of that box only contains one channel, the one you're tuned to. So you can take the output of the Dish Box and send it into your ATI tuner card, but you cannot change the channel to anything other than what the DIsh Box is set to. I'm sorry, but that's just the way it is. I use a Hauppague tuner card that has what's called an "IR Blaster". By hooking this device up to my Cable Box and I can used my computer to change the channel on the Cable Box itself.
If you had cable, you could run the cable into the TV tuner and watch the analog channels. I have Time Warner in my area and they still broadcast about 50 channels in analog. I cannot use the tuner card to watch any of the digital channels. This probably does not help you, but I thought you might like to know.
I want you to know that I don't get paid to offer these suggestions. I know it's a strange hobby, but I like to help when I can. Even though I cannot solve your problem I hope I provided helpful information and you will give this solution a positive rating. I've noticed that many times this type of question goes unanswered because nobody wants to get a bad rating when a problem has no solution. Thanks and good luck.
Jan 02, 2008 | ATI TV Wonder 650 (DNH100715331) Video...
Toshiba 52HM95 52" HDTV Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
