Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
What wires go to what
I stupidly took off the old thermostat without labeling the wires. Yes, I am blonde. Anyway. I have a Honeywell Magicstat CT3200 which I do have the instructions for, but still can not figure out what to do. I have a white wire that I know goes to W, I also have a black wire that I believe is the ground, but I am not sure. I also have 2 brown wires, and that is where I am confused Can you please help?
Thanks,
Angelina Hall
  • 61 Answers
The colors you have are not standard.
Your going to have to see where the wires connect on your appliance to answer this. find out and post back
Posted on Nov 30, 2008
Can I replace my old Magic Stat CT3100 thermostat with a Honeywell CT3200 thermostat?
yes just make sure u relace all the wires in proper order, r-rc, w , y g,, remove one wire from old stat and install on new one or make drawing and write down all wireing colours and letters
Dec 21, 2015 | Honeywell Heating & Cooling
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
I have a two wire thermostat system. I switched the thermostat from a mercury one to the Honeywell CT3200 with dip switches set for my electric forced air furnace that is 31 years old. The white wire is...
If you look closely at the installation manual page 6&7 it tells you settings to use for your type of system. If I'm not mistaken you will need to back out screw "b" 360°. Hope this helps!
Jun 17, 2017 | Honeywell CT3200 5-2 Day Electronic...
I only have 2 wire from the old thermostat... white and black. where do i connect them?
To R and to W. Probably black to the R and white to the W If your new stat has Rh and Rc you will connect to Rh
Jan 22, 2011 | Honeywell CT3200 5-2 Day Electronic...
Replacing thermostat what to do with single red wirew/bridge?
yes u leave the bridge intact and just put ur red wire to r or rc and usually they say rh and rc that is for a 2 transformer system which obviously u dont have so leave the wire intact jumped and hook ur red wire up yellow is ur ac wire white is ur heat wire and green is ur fan wire and red is ur 24 volt hot wire all a tstat does is jump that red wire to white for heat green for fan or yellow for ac but make sure ur power to ur unit is off before u change wires or u risk touching wires together and burning up transformer
Feb 24, 2010 | Honeywell Programmable Thermostat Heater
I bought a honeywell ct3200 and not sure how to hook it up to a two wire system. The wires coming out wall are black and white
If you just have two wires coming from the wall then attach them to the terminals marked R (may say Rc and or Rh, usually has a jumper installed between the two) and W. Hope this helps
Oct 05, 2009 | Honeywell CT3200 5-2 Day Electronic...
Pins on back of thermostat one broke off inside unit weld broke
has it always worked or did you just put it in some require 24 volts to work a wire from the thermostat to furnace c terminal
Apr 28, 2009 | Honeywell CT3200 5-2 Day Electronic...
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Jun 05, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
148 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
