Question about Zooper Boogie - Red Jogger Stroller
Steering problem - Zooper Boogie
2004 Boogie stroller does not steer properly. Is only functional when front wheel lock is on, and is still very difficult to steer. My husband thinks it is the front wheel bearing that needs replaced. Any suggestions on where I can order parts?
I seem to have a similar problem with our 2005 Zooper Jazz. I took the front wheel apart and found that the balls in one of the three bearings where full of rust. I've have contacted Zooper, but am not getting my hopes up, as suggested. The replacement balls should be readily available locally, but I need to figure out the exact sizing first. Putting the front wheel back together again may be a challenge.
Posted on Aug 20, 2007
I had the same problem and took it back to where i bought it. THey sent it in and had the whole front wheel and corresponding parts replaced. A few weeks later the same probem occured. I just sold the stroller as is. You could try to contact Zooper directly, but don't get your hopes up, sorry.
Posted on Aug 10, 2007
Flat tire on zooper boogie - where would I get a replacement inner tube or new wheel, live in Toronto, Ontario
Canadian Tire...you need a 12" bike tire tube. You should find them near the kids bikes.
Jul 22, 2011 | Zooper Boogie Jogger
Our zooper boogie red jogger stroller has had problems for a long time, the front wheel is very hard to push and lock, the whole stroller seems really hard to handle, it just wont turn or go where it needs...
Hi I had a similar problem with mine. I ended up just tightening the cable that connected the front wheel to the lock. (screw-like connector bolt under lock) You may want to adjust the cable as well sounds like it needs to be loosened maybe. I hope that I helped. Good luck! :)
May 03, 2010 | Zooper Boogie - Red Jogger Stroller
Where can I find parts for this stroller ?
Hi , I have just found out that Zooper no longer makes the boogie... :0( I'm having the same problem...Good luck with your search....
Apr 13, 2010 | Zooper Boogie Jogger
Zooper boogie 2005 needing rear tires, canopy, seating material
Are you still looking for parts? shipp.daniel@gmail.com
Sep 08, 2009 | Zooper Boogie Jogger
Zooper Boogie User's Manual
There's a safety lock located on the right side of the frame, about 6-8" down from the handle bar. There are also 2 sliding locks, one located on either side of the stroller, on the underside of the frame. One is located just below the safety lock. First pull up on the safety lock, and while keeping the safety lock open, simultaneously slide the other 2 levers up toward you. The stroller will unlock/open and you will be able to fold it.
Dec 24, 2008 | Zooper Boogie Jogger
Zooper Boogie Black 2006 Need New Seat Insert
You can buy them on the internet. Hope this helps.
Apr 30, 2008 | Zooper Boogie Jogger
Zoooper buddy stroller
No, there's no way to make it swivel. The Zooper Boogie has a swivel wheel- or it can be locked into place with the flip of a switch!
Mar 30, 2008 | Zooper Cool Zone Buddy Stroller
Making my zooper available to 2 children with an attachment
First of all, a heartfelt congratulations! Second, it's definitely challenging having children so close together.
The Zooper Boogie is a good stroller and it's engineered in a VERY specific way to provide baby safety and comfort. It does this by providing a slightly lower center of gravity focused on the rotating single front wheel. This makes it more maneuverable for parents and keeps baby at the center of the swivel. Attaching a second compartment on the front or back of this particular carriage would undermine the engineered balance, tremendously. At least one occupant would suffer from an extended swing when maneuvering that could be more than just uncomfortable, especially if it was extended forward over the front wheel. Some stroller companies might be willing to do this, Zooper doesn't.
The best alternative that they offer is the Tango which is engineered for two. I know that you mentioned that you wouldn't purchase a double stroller but modifying a single might be uncomfortable and possibly dangerous for your little ones. I would recommend against it.
Once again, congratulations on your blessings!
Nov 11, 2007 | Zooper Boogie Jogger
Problems with releasing front wheel lock
I have just fixed my stroller which had a similar problem. The wheel was still swivelling but it was sticking slightly. I noticed that the pin that locks the wheel in place was half out and therefore the wheel was getting caught on it. I undid the nut that holds the end of the wheel lock cable in place and tightened this as tight as I could which pulls the pin back into place (making sure that the switch is in swivel position). I then put the washer and nut back on (making sure cable was as tight as possible).
May 30, 2007 | Zooper Boogie Jogger Stroller
Zooper Boogie - Red Jogger Stroller Logo
635 people viewed this question
Top Zooper Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Zooper Baby Gear Expert? Answer questions, earn points and help others
