Question about Truly MP313X 1 GB MP3 Player
Can't charge battery
I misplaced the charger for my Truly and it won't charge off of ANY of the computers I've tried it on, that's three different laptops and two desktops, all with USB 2.0 ports. What the heck is going on here? I'd really like to avoid spending $30 or so for another USB charger.
Try another cable. Some don't work
In these otherwise good machines, the battery may come loose. Then they won't charge no matter what.
Posted on Oct 18, 2008
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
My nokia E5 won't charge, I've tried another charger but still nothing
can you see the pin in the charger socket? these can get bent, other wise looks like your charge socket has come free, from the board
May 16, 2012 | Nokia E5 Cell Phone
My computer won't turn on
If you tried turning the laptop on with NO battery but plugged into the mains and you get no response, even no little lights flickering then its possible that something to do with the motherboard (obviously, you might think) but get someone too look inside it if you can, something might be fried.
its a bit hard not actually seeing the machine
May 09, 2012 | HP Computers & Internet
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Hi, i've had my Samsung genio touch for over a year now and i've had no problem untill now, the phone will not charge up, i've tried putting the charger in a different socket and taking the...
a possible battery or charger problem.
check if you can charge using a diff. charger,if you can?then the charger is the problem,replace it.
but if you can charge w/a diff. battery?replace the battery. :)
Sep 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
HTC Hero won't charge. I bought a new battery...still won't charge. I've tried a wall charger and a car charger and neither of them work.
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
Sep 01, 2011 | HTC Hero Smartphone
I've got a Bosch ps30 drill that uses bat411
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
Jul 15, 2011 | Bosch PS30-2A 12-Volt Max 3/8-Inch Drill...
I have two drills, two chargers, and three batteries. All of the batteries stopped working at the same time, won't take a charge. I've tried both chargers, charging the correct amount of time. Is...
I have to agree, I assume you have tried the the same battery on both chargers? is it possible that one charger ruined all the batteries? I wish I could offer some real help other then to say "hmm." But my best guess is that one charger ruined all the batteries. unless you use them both at the same time, then it would be hard to have them all quit at once. -
Jun 20, 2011 | Black & Decker Drills
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Truly MP313X 1 GB MP3 Player Logo
Top Truly Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
 steve
steve
Are you a Truly Audio Player and Recorder Expert? Answer questions, earn points and help others
