Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA DLP TV needs color wheel replaced
Need to know how to replace the color wheel on RCA's HD61LPW42. This 61 inch tv had the wheel replaced twice before but now its off warranty and I want to do the $500 repair myself. Is there a manual for this repair?
  • Anonymous May 11, 2009
    color wheel need replcement
  • Anonymous Mar 16, 2014
    how to change color wheel rca model hd50lpw42 dlp tv
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
Posted on Nov 30, 2008
SOURCE:
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 48 inch rca dlp tv that does nothing except blink green light in front and makes a loud noise no pic no sound. do i need to replace the lamp and the color wheel or juss one of them, or should i...
Hello my friend...
probably you do need to change your color wheel have you change your TV lamp?
here is a website were you can check prices they are really good not to expensive.
and yes i recommend to buy just the parts and not a new TV fix the one that you have
http://www.discount-merchant.com/Factory-Original-Lamps-Bulb-For-your-RCA-Scenium-p/rca-lamp-265866-26591-269343.htm
http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsung-cw-bp96-01579a-enc.htm
the prices may go lower depending on your TV part.
good luck.
Mar 17, 2010 | Televison & Video
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
I need help with my rca tv
probably bad color wheel. not an easy repair. some of the rca dlp required the light engine be
pulled out to replace color wheel.
Feb 24, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
Phillips DLP 50 inch has no color great black and white picture
There is no color chip. What it does have is called a motor driven color wheel. The problem is that the color wheel is no longer spinning to produce color. Replace the color wheel and you should be fine.
Dec 31, 2008 | Philips TV Tuner Video Capture PCI Card -...
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
1,088 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
