Question about Kenwood Audio Players & Recorders
I have a Kenwood KR 2600 with a scratchy sounding left channel on both the A and B speakers - any suggestions on where to start?
5 Suggested Answers
  • 17 Answers
SOURCE: Kenwood Receiver KR-V127R - left channel not working
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear equal humming on both channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
Posted on Jan 01, 2008
  • 3422 Answers
SOURCE: I have a Kenwood KR-V7030
HI,
The protect message means that a problem was detected and that the output speaker connections have been disabled.
Posted on Jun 29, 2008
SOURCE: Kenwood VR-405
vr-405 does not have a digital decoder, so the digital signal is what you're hearing
Posted on Oct 14, 2008
dunnbiker
  • 8546 Answers
SOURCE: I have a Kenwood KR-V9030
There is a chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure.
One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you're losing it in the preamplifying or source selection stages.
If it CAN be played externally, the receiver is losing it on its way to or at the amplification stage. Further isolation would require hands-on technical expertise.
Posted on Apr 16, 2011
One channel has no bass. what should I check first under the cover
No bass like speaker isnt working? If so first thing a would try is switching speakers...If it fixes that channel then its your speaker.
Mar 23, 2016 | Kenwood KR-V7080 Receiver
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
It is a kenwood model kr-3090 the left side does not work for the speakers
If You have already switched speakers To confirm it's not the speaker that is the problem then the channel is out
Feb 24, 2013 | Audio Players & Recorders
I have a Kenwood kr-v8010 and all a suddenly one channel is only working just woundering if its a easy fix?
Could be a speaker wiring issue, defective speaker or possibly a speaker protection fuse inside the unit has blown.
1. Check speaker wires for proper connection.
2. Swap left and right speakers to see if the problem follows the speaker.
3. Check for internal speaker fuse that may have blown. PLEASE proceed with caution inside the unit. With the AC cord unplugged there are still high voltages resident inside...BE CAREFUL!!
Oct 31, 2012 | Audio Players & Recorders
KENWOOD KR-V8030 SPECS
I have had this exact Receiver and this is taken right from the specs. in the manual, "120 watts per channel RMS" at 8 ohms - this is in Stereo mode (2 speakers) only". When surround sound is used, "75 watts RMS for Front and Center speakers and 15 watts RMS for rear (surround) speakers. From experience, the Stereo only mode is definitely stronger/louder than when switching to Surround. Most newer receivers are the same wattage regardless of mode.
Feb 19, 2012 | Audio Players & Recorders
Hi, My friend (who has a visual impairment) moved house recently, they own a Kenwood KR - V5570, I assisted with re setting up PC etc. I am now baffled with connecting her left and right speakers to this...
If you keep guessing you may succeed in blowing something up.
The cables have RCA connectors or bare wires for a reason.
Get the manual out and read it.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V5570-Receivers-manual/id/479bh938/t/2/
Don't pay too much attention to the actual colors of speaker wire. Use the colors as reference. Each speaker has a plus and a minus. Connect them to corresponding plus and minus for their respective amplifier outputs.
Jul 04, 2011 | Kenwood KR-V5580
Left speaker problem with X-240 Logitech Speaker / Subwoofer Sys.
pul the board out of the subwoofer box and check that the connector is soldered to the board properly if not the sound will sound scratchy.
hope thes helped
Jun 06, 2009 | Logitech X-240 Computer Speakers
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
Dec 31, 2007 | Audio Players & Recorders
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
