Question about Element Electronics FLX3220F 32 in. LCD TV
Tv goes off cant get it to come on
Tv just shut off on its own cant get it to turn on
  • 1,238 Answers
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 08, 2012
SOURCE:
Tv plays about 2 minutes and picture and sound goes off, comes back on.Does this 3 times then tv shuts.turn tv back on and repeats sequence.
there is main board defective please replace the main board 3 time blink is dc alert which is happened in side the system ic & we cant replace the system ic so we replace complete main board
Apr 20, 2015 | Sony BRAVIA KDL55HX750 55-Inch 240Hz 1080p...
Cant turn tv on
may be your DM board is gone......
Mar 08, 2008 | LG RU-23LG10P 23 in. TV/DVD Combo
WHY TV KEEPS SHUTTING DOWN AFTER ABOUT TWO SECONDS AFTER YOU TURN POWER ON WITH NOTHING ON SCREEN
If the light just goes off then look at the ballast . If the whole set goes off then look at the power supply board.
Jan 24, 2014 | Philips 50P8341 50" Rear Projection...
The Screen Turns Green then shuts itself off? Is this the Bulb or something else?
My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. [email protected]
Feb 13, 2011 | Sony KP-65WS500 65" Rear Projection...
I cant turn off my shut off valve that goes to my
Hi!
Are you talking about the gas shut off valve or a water shut off valve(if you have a boiler)? Either way if you can't shut it off you need to get it replaced. Good luck!!
Dec 31, 2009 | Heating & Cooling
I turn on tv shuts off after 30-45min. red lite goes dim
It's likely that the TV will require service since your troubleshooting steps didn't resolve the problem. If your TV is smaller than 30", you may carry it in to the retailer of purchase for repairs. Otherwise, service for your TV can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Nov 19, 2009 | Televison & Video
Shuts off
Reedasaurus resolder your flyback.
Neednonrcatv, you need a new flyback you can get one at the following link with free tech support so you can install it yourself, very easy repair you need flyback number 259296 heres the link.
http://servicemanuals.vstore.ca/
Apr 22, 2008 | RCA Scenium D40W20 40" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
I have a LG RU-44SZ61D DLP TV and recently replaced the bulb. After about two months the TV went really dim and then started shutting off. The problem increased to the point where you couldnt have the tv...
DLPs have flow chart trouble shooting techniques to pinpoint exactly why your set isnt completeing the boot sequence. If you would like the service manual for your model let me know and i will post a link where you can purchase a complete one.
Apr 06, 2008 | Televison & Video
27 inch Digimate LCD TV Shuts Off Automatically
have you had this probelm fixed mine just starteed to do it and its only 8 months old and I cant afford to have it fixed please help if you can thanks
Feb 04, 2007 | Digimate DGL26 Television
Element Electronics FLX3220F 32 in. LCD TV Logo
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
