Question about Dryers
My electric whirlpool senseon dryer won't heat
Everything else seems to be working, turns on just won't get hot. I checked the vent and it's clear, I don't have the meter to test anything, is there anyway I could fix this myself I really can't afford a repair person its from 2002. Thanks.
  • naps1977 Nov 30, 2008
    my dryer turns on, i have no heat, and the timer doesnt advance. the drum goes around, but thats it...help paula
  • sglasman Mar 24, 2009
    I have the same problem???
  • 116 Answers
Lint screen on top///repl/thermal fuse in rear of dryer, if screen inside dryer remove front bottom panel, next remove blower housing on top off is the other thermal fuse ,, gurantee fix
Posted on Nov 30, 2008
  • nancy_andre Nov 05, 2010
    Where is the other thermal fuse?
Dryer heating but cloths not drying
Hi Is good you start from wright leg Is probably limit sensor (not expensive) and next program board (is expensive). No error codes?? Check also outlet at wall where is connected vent pipe. Good luck.
Oct 19, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Senseon dryer control panel won't work
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
Oct 14, 2012 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 19, 2011 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
My dryer does spins and turns on, giving minimal of hot air. Knob usually turns as the load is almost done. knob is now not turning at very hot mark on perm press cycle. Vents are clear.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | Maytag PYE2300AY Electric Dryer
My dryer wont heat
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Mar 16, 2010 | Whirlpool Dryers
Whirlpool dryer not heating up
first you need to check your breakers or fuses in your home's breaker box, try turning the breakers off then back on again (if you have fuses ,check them or replace them). If everything is ok there then you need to access the heating element(with the power off) test to see if you have continuity in the element then the high limit& the thermal cut-off. Sometimes dryers seem like they are not heating when the dryer vent is kinked or clogged. This is the number one thing that I find when servicing dryers. Usually when the vent is clogged or kinked I correct that problem first, then continue with the other things . you can quickly check that by unhooking the vent and run a partial load just to see if that works. while the vent is unhooked you can start the dryer and feel the air coming out of the vent of the dryer to see if you are getting heat. You can check that without having clothes in it. let me know. Thanks
Dec 18, 2009 | Whirlpool GEW9868K Electric Dryer
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Dryers Logo
828 people viewed this question
Top Dryers Experts
