Question about HP OfficeJet K80 All-In-One InkJet Printer
K80 All in One Printer continual asks for new blck or clr cart
K80 all in One Printer posts "Remove and check black cartridge". I have been able to make that go away sometimes and it is replaced with "Remove and check color cartridge"
    Problem Solver:
I have a number of hp printers. All are all in ones. It has been my experience that sometimes any of them can give you a false mess on the screen. For my printers the ink used are #23, #15, #78, #45. Any of them either new, compatible, or refilled can be misread. My only suggestion is to ignore the mess, and either make 1 copy manually, or from the tower to see if the misread really is a misread or if the cartridge really is either damaged in some way or is the wrong one. Or you can run the alignment page. In either case the result will be either acceptable or not. Also there are many other hp printers that use the same #s, the 900 seires in fact. The 600 and 700 series use a combination of the #23 and #15, The v40 series also use the #78 and #15. These can be found in second hand stores or the national chain GOODWILL INDUSTRIES, similar but not related to SALVATION ARMY. I hope this helps.
Posted on Dec 30, 2008
Will not recognise black cart epson artisan 810
Ok, like most inkjet printers, cartridges can be a headache. I use alcohol and tissue to clean the spray heads of the cartridges. then it is important to clean the electronic connections of both the cartridge and the printer. This connection not only helps measure the ink cartridge but also senses if the cartridge is inserted properly. not sensing a new cartridge was a constant problem with a recent HP printer i bought. cleaning it solved that problem.
Jun 12, 2014 | Epson Artisan 800 All-In-One InkJet...
Printer message continues to come up that says "remove and check color cartridge." I remove it check it and put the lid back down and the message comes up again. Sometimes it says to press Enter to do a...
is ur cart a new installed or refilled??
howevr, dis often comes associated with d aforesaid..ignore n continue..u may also type in Run->msconfig..and remove all hp related startup programs esp hp monitor from startup tab..hope it'll work..else try to install a new n branded hp cart
Jul 09, 2010 | HP PSC 750 All-In-One InkJet Printer
Printer not recognising cheaper cartridges now and asking for new full cartridges to be replaced. kind regards Sandy
what make & model printer? check for protective tape over cart. print head.
remove if present. try running test printout option. perhaps the printer needs to recognize the new carts.
good luck!
Aug 11, 2009 | Epson Stylus Photo R300 InkJet Printer
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Problem
dear lisa
is your cartridge is original,just check with the old cartridge is the problem arises,post your findings
May 13, 2008 | Compaq A3000 All-In-One InkJet Printer
Error 1203
Are you using a refilled cartridge1.gif or refilling your cartridge yourself?
Error 1203 is an issue that occurs either when a cartridge is bad or the printer1.gif cartridge Slot is bad... Try to cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work, then you might try a new black cartridge and possibly a color cartridge too.
Hope this helps.
Good luck.
Mac
Please remember to post a feedback and or rating if my suggestion has helped you fix your problem.
Note: Refilling carts may damage the contacts of the carts as well as the printer (From a printer companies website)
(repeating this message again, for some reason this site logged me off and It didn't give me credit for the post)
Mac =)
Feb 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Hp K80 printer
I cleaned the vertical centerpost (you'll see it when the cartidge is out)with a small amount of acetone (nail polish remover) on a Qtip & it works fine now....must be some kind of circuit that needs to be closed and the ink on it kept it open....
Dec 19, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
Brother MFC-215C
unplug machine from power. remove all carts. close cover. reconnect machine to power. wait until machine demands carts. reinsert cart as demanded by machine and secure them by pressing them into position and fixing the clip above the cart cover. give correct answer as display asks. Set date and time again.
btw: always print until printer stopps printing! Never change cart befor that
because printer logic will be fooled ;-)
Nov 11, 2007 | Office Equipment & Supplies
Cannot print
It seems that another cart is empty. Check all cartridges when printer is off. And yes, you do need the color ones to print in bk.
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
HP OfficeJet K80 All-In-One InkJet Printer Logo
166 people viewed this question
Seeker5211
Seeker5211
