Question about Hobart A200 Stand Mixer
Hobart mixer 30 quart
Hello and thank you in advance . how do i change the grease in a hobart 30 quart mixer.
  • 41 Answers
This is an extremly difficult mixer to take apart if you are not tech minded do not attempt this
Posted on Dec 09, 2008
Grease for hobart c100
If you mean inside the gearbox then you need gear oil. Ask for it at a restaurant supply. if you mean grease for around other moving parts remember that it would be wise to find something that is food grade in case it gets into your product.
Oct 15, 2013 | Hobart C-100 10 Quart Mixer
Hello, my Hobart AE200 seeps oil from the front panel. How do I top it up? How often does the oil need replacing and with what type of oil? Thanks
It's not oil in the A200, it's #2 weight grease. Although when it gets old enough it can break down far enough to basically become oil (either that or someone put oil in it previously). There are a number of answers written on fixya.com explaining how to disassemble the transmission and change the grease. Fill with 36 ounces #2 grease. FYI : disassembling the transmission and changing the grease is a very messy task and one can VERY easily reassemble the transmission incorrectly, so consider bringing the mixer to Hobart to have the job done.
Aug 17, 2011 | Hobart A200 Stand Mixer
How do I empty and then refill the grease in the gear box of my 30 quart Hobart mixer
Transmission has to be somewhat disassembled, grease removed, lower seal should be replaced and then grease added and reassembled. Not that easy to do. Check www.hobartservice.com for your local Hobart office.
May 05, 2011 | Hobart A200 Stand Mixer
What maintenance is required on a unit built in the 1980's. What type grease is used in the head and how much? I use this unit at home for making various types of bread. I normally work with 10 pounds of a...
as long as there is leaks down the beater shaft, or grease drips from the drip ring on the planetary you should be ok. the grease needed for the a-200 series mixer is a -47you can get @ any hobart office. buy 2 quart cans ,use 1.5 cans, there is an absorbtion rate capacity chart on the web for all hobart mixers to see if you are overbatching the mixer. hope this helps,
Dec 23, 2009 | Hobart A200 Stand Mixer
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
Trying to locate a wire whisk for my Hobart D-340
Bill. Whisks are not interchangable for different bowls. Try ebay to locate one.
If this solution has assisted you, please rate it. ricardok45
Mar 20, 2009 | Hobart D340-6009 Mixer
Old man needs help with hobart 30 q mixer
it has to be torn apart to change grease and it is grease do not put oil in it. but it all is done from top under cover is the top of transmision the round cover comes of and all shafts need to be removed and I sugest a new main shaft seal and hub seal while your at it.
Nov 29, 2008 | Hobart A200 Stand Mixer
Hobart 20 quart mixer
Hey tom dont worry about it.These mixers hold a decent amount of grease.If you need any other info let me know.
Jul 23, 2008 | Hobart A200 Stand Mixer
Servicing Hobart A-200
these mixers dont use oil,they use grease.you will have to open the transmission to change the grease.any ? let me know im a hobart tech.
Jan 25, 2008 | Hobart A200 Stand Mixer
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
412 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
