Screen says ''no signle''
After playing on the thing for awhile this message popped up and cannot do anything with it now
I have a p4i45gv motherboard.my monitor says that no input signal, when i switch on cpu. i have checked all computer cables. its working perfectly. no doubtable. have any solution
Posted on May 13, 2009
    Guru:
  • 859 Answers
No Signal as a message on your Display indicates a loose cable in most cases. With a flat panel this is usually where the cable connects as that spot on the flat panel is often difficult to access. It is best to remove the cable and reattach. Then use a slot screwdriver to tighten the thumb screws down snuggly. Do not over tighten when using a screwdriver. The same is true at the back of your computer. Remove and reattach the cable and tighten down with a screw driver. Your cable should be attaching to the same color connectors at the back of the computer and the back of the Display panel. You can try swithing over to the other set of connectors, when two connectors are present.
Should this not solve your problem or you have already done this then you have a loose display adapter card in a slot inside your computer. To know if you have a display adapter card and not a chip on the motherboard, look at the back of the computer. If the display cable connects vertically along the lines of the cabinet nearby the mouse, keyboard and USB ports, then you have an onboard display adapter and this cannot be loose as it is a chip soldered onto the motherboard.
If however, you have the cable connected in a horizontal position in the bottom half of the back your are using an add in device card that is physically inserted into a slot.
In this situation, you need to remove the side panel, and or the cover. While looking at the inside of your computer you will see a PCB board in a slot and the display cable connected to the outside end. Remove the cable, look where the display card is inserted. At the end at the cabinet side there should be a screw holding the card into place. Remove this screw. Then at the far right end of the display car there may be a latch near the motherboard surface that is or isn't latched correctly and this loose connection of the card in the slot will be sufficient to cause a Signal Loss error message. Release the latch if needed and remove the display card. Be careful about static electricity discharge. Just try not to move around a lot while doing this. Once removed, just reinsert the card using considerable force to lock the card into place. Push firmly straight down on the card. Once this is done, reinsert the screw at the cabinet end, reattach the cable and boot up again.
This process you have just gone through will rule out any and all potential loose connections in the path from the motherboard to the display.If you still get a Signal Loss error message, you may have the cable connected to the wrong plugs. Often there are two, two on the display adapter, whether a card or onboard. One would be Blue the other White. The same is often true at the back of the Flat Panel. You may have two connectors there as well. One Blue and one White. If the cable is connected to both Whites switch to both Blue. Normally, the cable should match the color connector on both ends it is attaching to. On the back of your display adapter you may have two white plugs. In this case it is designed to allow you to use two monitors. Try switching the cable to the other plug an so on.
If you have any further questions or need some assistence further on this don't hesitate to use the Comment Box below to respond. I will get an email alert of your comment and get back to you as soon as I can in my day.
Regards,
Worldvet
Posted on Nov 29, 2008
  • Glenn Rogers
    Glenn Rogers Dec 04, 2008
    Was your problem solved?
Can't play the sims 2 double deluxe on my laptop
Could you take a screen shot of the thing that pops up with print screen? Pretty much when it pops up hit the button called print screen, open paint then right click and click paste then save it.
I can help you more afterwards after I see the thing that pops up.
Feb 25, 2013 | Sony VAIO Computers & Internet
When playing games in facebook I cannot send and recieve gifts and keep getting things blocked, why does this always pop up at top of games ?
You need to adjust your pop up blocker to allow pop ups for Facebook. Typically IE8 gives you a message at the top of the screen when a pop up is blocked with the option to allow pop ups from this site either for this one session or forever. if you do not see this you can adjust your settings by clicking "Tools->Pop up blocker->Pop up blocker settings."
You may also need to adjust the security settings for Facebook from "Tools->Internet Options->Privacy." Make sure you adjust privacy settings for facebook only!!
Apr 14, 2012 | Microsoft Internet Explorer 8
Analog out of range display on the screen
try the lcd monitor on another PC, if the same message pops out, your monitor needs reprogramming of its A/D board, bring it to a LG service center..
if it works fine on another PC, try to boot your PC on VGA mode..
May 10, 2010 | LG 22" FLATRON LCD Monitor
Invalid URL error message
No facebook has just messed things up, your better off not playin.....its actually cafe world that has the most...the more people that stop playing it the more theyll wanna fix it so stop playing for awhile go back and see if its any better
Apr 05, 2010 | Facebook Social Network
I have a Nikon D80 camera that is about 1 year old. I has worked fine until about 6 months ago. Sometimes when I turn it on and press the button to take the picture nothing happens. I have to wait awhile...
Are you getting a Err message? If so The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Mar 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
When I was playing a Game Cube game on my wii. Somthing popped up saying if I wanted to switch to some mode. I Clicked yes accidently and now when I turn on my wii It Doesnt show anything but a Blurry...
It sounds like you may have switched some video setting that your TV can't handle. Try removing the battery and leave it out for awhile (hour) and see if that helps.The battry is in small bay on the botton of the wii and is held in with 1 small screw. Good Luck
Nov 23, 2009 | Nintendo Wii Console
Sounds when "sending" or "complete" message pops up
I think you need to turn the system sounds off. You can do this by going to Control Panel and clicking on the Sounds icon. Mush through that and see if you con find anything.
Jun 14, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
To play Rock Band without vocals?
Seriously you guys are hilarious, nobody's even given this guy a true and or correct answer. I too have had this problem and it's INFURIATING. Just trying to play the damn game: No you don't have to download anything
Solution:
Enter Game mode/ Training mode whatever mode USING THAT INSTRUMENT. I repeat DO not use the controller (the xbox360 controller) unless you want to use the microphone. It makes sense the microphone has no control hence by default if your'e using the controller the game THINKS you want to play with the microphone.
ROCK ON!!
Feb 24, 2009 | EA - Electronic Arts Rock Band
Administrator Problems
Hey,
there is a cd you can burn and use to reset the password. that cd is available at http://home.eunet.no/pnordahl/ntpasswd/
Thanks,
Ekse
Aug 29, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
383 people viewed this question
Alun Cox
David Payne
David Payne
