Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Instal psp power switch (plastic exterior part)
How do u instal the psp power switch i dont mean the acutal wired switch just the plastic part that conects to the iner switch?
  • 347 Answers
You will have to open it up and void your warranty, let me know if you would like assistance opening up your psp.
Posted on Sep 13, 2011
Bentley Boot lid manual release
This is all the Bentley shows:
Location: Driver's side door trim in storage compartment.
- Remove driver's side door trim:
Repair Manual, Body Interior, Repair Group 70 - Unplug connectors.
Carefully disengage catches -arrows-.
- Press switch for interior monitoring and towing protection -1- or trunk release switch -2- out of trim toward rear.
Installation is carried out in the reverse order.
Remove trunk lid lock.
Repair Manual, Body Exterior, Repair Group 55
- Use a flat screwdriver to pry plastic tab -3- off retaining pins -1-.
- Bend plastic tab fully to rear.
- Pull contact switch -2- first sideways and then up and out of trunk lid lock.
Install in reverse order, paying attention to the following:
Make sure that washers are correctly seated between plastic tab and trunk lid lock.
Sep 01, 2012 | Bentley Continental Flying Spur Cars &...
The brake pedal of my 79 firebird is so loose that the brake lights stay on, draining the battery, and I cant figure out where the problem is, I dont know if something has broken, and fallen out, or if...
If by loose, you mean it also has lots of side to side play, there may be a worn plastic bushing at the hinge. If it's just the up and down movement you are referring to, the acutating pushrod may have an adjustment to take up the slack or you could install/replace a return spring. Hope this helps.
Jun 24, 2011 | 1979 Pontiac Firebird
Hyundai tucson 2007 rear door wont open, alarm switch, power switch and key will open all doors except rear.
Sounds like the acutator that pushes and pulls. either lost power or died. I would assumed died. U need to check to see if it is on a seperate fuse first, it may be. If the fuse is ok, remove the hatch inside plastic panel and arm and disarm the alarm. See if the actuator moves.
Dec 08, 2009 | 2005 Hyundai Tucson
Psp power switch broken
well, you will need to disassemble and try to fix with a bonder glue the plastic button, cause sometimes the plastic pins brakes..or maybe the eletronic button is dead and you will need to buy a new one replace and resolder for psp parts in ebay...Good Luck
Sep 10, 2009 | Sony PlayStation Portable (PSP) Console
My side mirros dont work
The exterior mirrors:
  • are controlled by power controls on the LH front door trim panel.
  • are of a foldaway design.
  • may contain turn signal indicators.
  • may be heated when the heated back window glass is activated.
  • may have a programmable recall memory option.
Driver Seat Module
The power driver seat and power exterior mirrors are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option.
Power Exterior Mirror Operation
The power exterior mirrors are controlled by the DSM and are operational all the time, whether the ignition switch is on or off. Using the power exterior mirror switch, the driver can adjust the driver and passenger exterior mirrors four ways.
Visual Inspection Chart Mechanical Electrical
  • Exterior mirror(s)
  • Interior mirror
  • Central junction box (CJB) fuse
  • Circuitry
  • Exterior mirror control switch
  • Exterior mirror motor
  • Interior mirror
  • Driver seat module (DSM)
  • Memory set switch
  1. If the vehicle is equipped with memory exterior mirrors and the concern remains after the inspection, connect the diagnostic tool to the data link connector (DLC) located beneath the instrument panel. Select the vehicle to be tested from the diagnostic tool menu.
    • Check to make sure the program card is correctly installed.
    • Check the connections to the vehicle.
    • Check the ignition switch position.
  • The mirrors are inoperative
  • Circuitry.
  • Central junction box (CJB) fuse.
  • Exterior mirror control switch.
Apr 07, 2009 | 2003 Lincoln Navigator
Power comes on and it automatically turns off after a while.
try useing recovery mode, hold the R trigger and turn off the power button, then switch the power button back on while holding the R trigger ,that dont work try taking the battery out for some time...
Aug 17, 2008 | Sony PlayStation Portable (PSP) Console
My power switch
you either have a broke power button or a bloew fuse on your psp. if its just the power botton you can buy a new one on ebay for about 10.00 and install it your self. if that dont work then u have a blew fuse and inlease you know how to solder on motherboards then your going to have to buy a new mother board which will cost you about 90-110 or buy a new psp which is about 170.00
May 18, 2008 | Sony PlayStation Portable (PSP) Console
Sony playstation portable
It might be a problem with your battery pack, you can even switch on your psp without battery pack, with the charger plugged in acutally. So a replacement battery will be a good choice for you.
Dec 24, 2007 | Sony PlayStation Portable (PSP) Console
Switching on my psp after charging it
Please mention after switching on the PSP power LED turns on or not? ================================================= Suppose without connecting the charger when you power on your PSP you will see green light and you will get sound clear with no display at all and after 1 min: PSP will turn off automatically. then 99% it means that your PSP is bricked.
Aug 01, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
