Question about Eureka WhirlWind 4381 Upright Vacuum
No suction. Picked up dog hair but went into extension hose socket and not into cannister. Is now blowing instead of sucking. This is a Eureka whirlwind lite. Thank you Jim
Mine is doing the same thing, the hose picks up things fine but the rollers turn and instead of picking up it is blowing air out????
Posted on May 25, 2009
Eureka vaccuum blowing out and not sucking in
Hi There,
I am going to assume you are talking about a Eureka upright vacuum.
The cause for this is generally either
A) Broken Belt - Which you can easily fix by changing belt
or
B) Blockage in the hose somewhere - Basically test the suction with the machine turned on with you attachment hose and see if you have suction. If you do check the belt and make sure you clear out any muck left around the roller.
If you need Eureka vacuum belts go to VacuumSpot.com.au
May 13, 2012 | Vacuums
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Hoover dm6200 blowing air
check your suction hose again, follow it to where it goes into the body of the machine. I assume this will be near where the bagless cannister is. Remove the bagless cannister and look up inside to where the attachment hose should come into the cannister. I believe you are still blocked up there. using a butter knife or something along those lines should free up the blockage.
Also, if that is all clear, try re-adjusting the dirt cannister as it may not be on properly to create your suction flow through the hose.
Good luck and let me know if I can help further.
Jan 24, 2012 | Hoover Vacuums
My eureka 437 stopped sucking
I believe the filter on your vacuum is clogged. Bagless vacuums require the filter be brushed or washed and dried, If they are not, the filter will clog, resulting in the reduction of suction. Clean filter about every 3 months or sooner if the same problem happens again. Hope this helps.
Aug 20, 2009 | Eureka Vacuums
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Lift-Off Pet Hair vacuum doesn't lift off pet hair!
very light "stuff" like dog hair will get stuck to the filter since that is where the suction goes. it's primary purpose was to keep dust out of the motor. This is a problem with many "bagless" cleaners. A bagged cleaner keeps all dirt and hair away from filters by utilizing the bag as primary filter. If you have alot of dog hair then this may have been the incorrect choice of a vac. all you can do is brush off the filter each time you use the vac. it will still pick up o.k. even when there is hair on the filter unless you leave it on day after day.
Jun 14, 2008 | Bissell 37604 Lift-Off Pet Bagless Upright...
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Kenmore Bagless Issue
after cleaning the filter,replace the bag.But this time before you close the lid,make sure you remove the hose.after the lid is closed then put the hose back on.
leaving the hose connected to the lid after closing will create a gap between the bag holder and the bag.so just remove the hose first before changing the bag
Jun 16, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Eureka Enviro Vac Model 4470 Not Sucking
First, check to see if there is suction without the hose on the base. If not, and there is no blockage, the problem is likely a damaged impeller, the small fan that makes the suction. That will have to be replaced.
May 21, 2007 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka WhirlWind 4381 Upright Vacuum Logo
929 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
