Question about Amana Heating & Cooling
Hello, I have an Amana Air Command 90 Furnace and would like to know if it is normal for this unit to cycle on and off 5or6 times before staying on? Thank you Ed
  • 182 Answers
Clean your flame sensor
Posted on Nov 30, 2008
I have amana 90 air command with aprilaire 550 humidifier i found water under my furnace today . we had one 80degree day so I uncover my airconditioner and than we had snow and i forgot to cover it back up...
Hello, it's kinda diffucult to tell where the water is coming from without actually seeing it, but since you say it is coming from the bottum of the furnace it might be that the condensate pump might be clogged up or one of the hoses could be leaking that leads into the condensate pump. One other thing to check would be the humidifier, somtimes they can either leak from the drain line or the humidifier itself, check these areas out and and ask me further questions if needed.
Apr 19, 2011 | Amana Heating & Cooling
Have an Amana air command 80 sse... and a HOT house! The AC comes on for a few minutes and then shuts off. The filter is clean... am wondering if there's a reset button. I have looked all around and...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know. Roger
Most condensing units have low pressure safety switches in them. If your system is low on refrigerant, the compressor will run a little and shut off. When the pressures across the compressor equalize, it will come back on. This cycle will repeat on till enough gas has leaked to stop resetting the pressure switch. If this is what is happening, shut the condenser off. Short cycling will over heat the compressor. You will need a technician to find and fix the leak. Also to recharge your system when repaired. Let me know if I failed to help. Roger
Apr 10, 2011 | Heating & Cooling
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
Hello, The problem is the ignitor comes on for a few seconds then goes out. The fan keeps running but no heat is coming out. Any suggestions? The model we have is Amana air command 90. Thanks.
Nov 28, 2010 | Heating & Cooling
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
Amana Air Command 80, 20 years old. Electronic ignition. Furnace does not start. Good power to furnace. Themostat properly set. Where do I start looking? Bob
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Thermostat properly set.
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Oct 12, 2008 | Amana Heating & Cooling
I have an amana air command 90 furnace. the burner won't light.
This unit goes in steps, 1-- thru--4 Step 1, vent fan blower motor runs & prove thru the air tube, which closes a switch and tells the circuit board to go to step---2 Step 2 lights the glow plug and goes to step 3 automatically, Step 3, opens the gas valve and send in gas thru the long venturi tubes which lights from the glow plug and on the last tube, theres a rod that sticks into the flame, if no flame or not working properly, it will shut down the starting sequences and retry for 4-times and automaticaly lockout till unplug and start over. (whever step it stops at, then thats where your problem is!
Sep 06, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
411 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
