Question about Garmin GPSMAP 196 GPS Receiver
GPS 196 will not pick up any satellites.
Turn it on and it shows the screen with the graph bars, which normally indicate satellites found. Used to work. Began dropping out occasionally during flight. Now it won't find satellites at all.
5 Suggested Answers
  • 40 Answers
SOURCE: Nuvi 660 fails to get satellites, resets don't help
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Posted on Jan 09, 2009
  • 4090 Answers
SOURCE: No satellite signal pick up
Yes ! 3 years is at the end of the expected lifespan of the battery
Posted on Jun 30, 2009
SOURCE: GPS won't pick up satellite reception.
Let's assume the unit is in good conditions. When you travel for more than 500 Kms the unit need more time to acquire the satellites, so the solution is to keep the unit on in a uncovered area for about 15 minutes.
Regards
Osiris
Posted on Aug 12, 2009
sharcnet
  • 2130 Answers
SOURCE: my garmin nuvi 360 just stopped picking up satellites
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Apr 19, 2010
How do I graph y=18.4cos(2pi/365)(x-196) 5.8? It doesn't show up in the graph on my ti 83 calc
hiArguments are in an invalid order, try multiplying the 5.8 with the other two terms (2pi/365)(x-196) that way yo might be able to graph it.
Mrmojorisin1
Aug 24, 2011 | Texas Instruments Computers & Internet
GPS locked up on me
This is an indication that your map unlock code has either been corrupted or is missing. Please see this link for more information on this problem.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Sep 01, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
Jun 30, 2009 | Garmin Forerunner 205 GPS Receiver
MY TOMTOM ONE IS WAITING FOR A VALID GPS SIGNAL I HAVE ALREDY STARTED TWICES
Turn on your tt and let it bootup. After it has booted up go to the map screen. On the bottom right where the bars are for satellite reception. Tap the bars this will take you to the screen telling you the device code etc. On the upper far right where the battery icon is tap the screen again. This will take you to a screen showing the satellites. If you see grey bars on the graph just wait awhile. Sometimes when your tt has not been turned on for awhile or you have turned it on after traveling a few miles it may take up to 30 minutes to get a lock.
Hope this helps
May 06, 2009 | Tomtom ONE GPS Receiver
Jan 02, 2009 | Garmin Nuvi 660 GPS Receiver
My Nuvi 310 can't find satelites.I have re-booted several times but without any Joy.the re-boot also locked on the map display The Mall in London.!?
There are a few things you can try to restore satellite reception.
1. place your finger over the lower left-hand corner of the screen and hold it there
while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings. This will clear some of the memory allowing your Nuvi to collect new satellite data. Your Nuvi should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
Make sure the antenna is up and that you are outside. On the main screen, you will see a satellite bar graph in the upper left-hand corner. Touch the bar graph and you should get a satellite map, showing the satellites. If your Nuvi's receiver is working ok, you should see horizontal hollow bar graphs appear on the right. Eventually they will turn solid blue. This indicates they have downloaded the proper data from the satellite. When you have (4) solid blue horizontal bars (4 satellites), you will see the top panel begin to show improved accuracy and your Nuvi will then work as it should. This entire process make take 30 minutes or less.
If you don't see any bar graphs, your Nuvi may ask you severl minutes later, if you are indoors. If your outside, select no. It will then ask you if you have moved 1000 miles since your last use. Select yes. This will cause your Nuvi to start looking for
satellites, trying to locate your new position.
Now, if you still don't see any bar graphs, then your antenna may have a problem. There is a known issue with the Nuvi antenna where a part has failed, causing the Nuvi to no longer use its internal antenna and it's now always looking for an antenna at the external antenna port (the gold connector on the side of the Nuvi antenna). If you have a piece of small wire, a couple feet long, you can insert that into the center lead of the external antenna jack. Most likely, you'll begin to see bar graphs after a few minutes and your Nuvi will lock.
I haven't been able to identify yet, which part has failed. I am working on that.
However, if the piece of wire works, you can always go on eBay or a retail store and
purchase an external antenna for your Nuvi. They are magnetic and can either stick to your roof or any metal surface within your vehicle.
Here's another way to determine if your antenna has failed and will have to be replaced:
At the main menu, pres on the "wrench" symbol. Then press the "gear" symbol and then press "about". There is a field marked "GPS S/W". There should be a number next to it. It may be "2.9" or "3.0". That is good. That tells you that the main board in the GPS is communcating with the antenna receiver. If you see "0.0" then your antenna is defective and there's no way to repair it other than replace it.
Please let me know if I can be of further assistance to you.
- Jim
Nov 06, 2008 | Garmin GPS
My Garmin Nuvi 360 we bought approx 1.5 to 2 yrs ago is now having trouble all the sudden finding satelite reception. We just had a major storm come thru our area and it seems to have happened just since...
If you don't see any bar graphs, your Nuvi may ask you several minutes later, if you are
satellites, trying to locate your new position. When you perform a factory reboot, your Nuvi thinks it's in Kansas (Garmin HQ) and so it needs to be told to look for new satellites.
- Jim
Oct 08, 2008 | GPS
Nuvi 360 cannot acquire sattelite
- Jim
Oct 03, 2008 | Garmin nuvi 350 GPS Receiver
I have a Garmin Nuvi 310 and whilst driving the other day it said "lost satellite reception" and has not been able to pick up reception since. I have updated the software from the Garmin website...
There is a known problem with the Nuvi antennas. Press the wrench icon, then the "gear" icon and then "about" and tell me what the GPS S/W field says. If it says a number like 2.9 or 3.0 that is good and tells me that the antenna is communicating with the main board. If it says 0.0 then the antenna is defective.
Also, try using an external antenna or just for fun, insert a piece of wire in the external antenna jack (with no shield) on the antenna and hold your finder over the satellite bar graph. You should then get a screen with all of the satellites in the sky.
Set the unit down with the piece of wire in the external antenna jack and see if it locates satellites after 10-15 minutes. If it's tring to find them, you'll see hollow blue bars appearing on the right and eventually they will download the data from the satellites and turn solid blue. When you get (4) solid blue bars, you'll see the accuracy rate start to go down and the GPS get more accurate.
There is a known problem with the Nuvi antennas where a part fails causing the antenna to no longer use the internal antenna and only will grab a signal from the external antenna port.
I am working on a fix for this.
- Jim
Sep 28, 2008 | Garmin GPS
No gps device
Sometimes it can take a TomTom many minutes to obtain satellites. To give it a chance and to test it make sure you have a clear 180 degree view to the south ( that's if you are in the northern hemisphere ) . Its to the north if you are in the southern hemisphere.
So, put the TomTom with it's back facing the equator ( all the GPS satellites are above the equator in an arc ) it's almost straight up in fact but towards the equator.
If you switch on , let it boot up , then tap the screen near the bottom right where you see a bar graph . ( see photo's and finger indicates where to tap position )
The screen will change to another screen and again you should have the bar graph on right hand side with a battery symbol either below or above. once again tap the bar graph and a larger STATUS screen should appear. You should be able to see the TomTom scanning for satellites . Any it receives will be GREY but grey ones are not yet locked on. If any of the bars on the TomTom get a fix or lock on they will turn BLUE . Only when the TomTom has 3 or more BLUE satellites can it present a fix on your location. If none of the bars on the graph ever turn BLUE then you have a faulty TomTom or possibly corrupted data on the SD card. If you get ANY of the bars turn BLUE then it's likely your TomTom is working OK but is just having difficulty locking onto any satellites. You might have to wait a while or move location.
Once the TomTom gets a fix , even if you turn it off then on again it will remember what satellites it was locked onto before so it should not need to scan again and should find the satellites real quick or at least quicker. See photographs below for the 3 stages to go through to check status.
( NOTE : The photograph shows a TomTom ONE v2 but almost all models of TomTom show similar screens ) See last photo where one of the bars is GREY , this shows it's receiving that satellite but it's not strong enough to get a fix from it. The last bar shows the TomTom knows there is a satellite there but currently has no signal from it. The BLUE bars show good reception and fixes on those satellites.
I do hope this helps solve your problem but if not then please revisit this forum and post any questions again and i'll see if I can help.
Please remember to rate my comments and recommendations if you have found them useful at all by clicking on the coloured diamonds on this page.
Aug 10, 2008 | Tomtom GO 300 GPS Receiver
Garmin GPSMAP 196 GPS Receiver Logo
99 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
