Question about Cell Phones
C3 citreon automatic
When I'm in top gear doing around 50mph theres a thud and the car drops to third gear and wont go up into fourth again until I stop , switch off and restart.
There is 2 flashing symbols , 1 snow mode and 1 sports mode.
My handbook says contact your nearest dealer.
Is this going to cost me hundreds of pounds in a garage.
Please help I'm at my witts end.
  • 3 Answers
SOURCE: white screen flashes until battery is taken out?
The white screen means that the lead linking the screen to the phone is lose, there are 2 or 3 leads, one lights the screen up, the other transfers data to be shown (like your menu etc), the one which lights the screen up is obviously ok but the data one, which is the longer of the two, had obviously come lose, it is possible to fix yourself if you search the internet to find how to take the case apart, its not too hard really, then if you have steady enough hands reconnect the lead, its quite delicate so be careful.
this link shows you how to take the phone apart. hope this helps
http://www.formymobile.co.uk/Dismantle/w850disassembly.htm
Posted on Mar 07, 2008
SOURCE: Help me sir with this damn restarting problem of 3110c
may be you will be having virus in your memory card ..............or, you may have too much of themes in your memory card this may lead this problem................so try by formatting your memory card ..............i hope i helped you........
Posted on May 14, 2008
short shadey
  • 421 Answers
SOURCE: automatic tiptronic gearbox sometimes sticks
have you had any transmission services done yet? like a flush sounds like a sticking solenoid but very hard to say with out looking into it please rate -jeff
Posted on Sep 01, 2008
  • 1118 Answers
SOURCE: blowers not working on 05 renault laguna
are the fuses numbered? are they behind a door on fuse box? if so, they should have coresponding numbers from back of door to fuse in box. if not than your only recorse is to pull one fuse at a time and chk. each one. make sure you only do one at a time so you donot get them in the wrong place. good luck.
Posted on Jan 06, 2009
solutionzone
  • 86 Answers
SOURCE: automatically restart mobile sgh j210.
your mobile is virous effected . So you can go to the mobile hardware point and solve it .
Posted on Mar 06, 2009
My 2005 Pontiac Bonneville GXP will not shift into 4th gear I was to it was a fourth gear band but is that the only problem that will cause itI'notto shift into 4th gear
Which transmission does yours have 4T65-E or 4T80-E ?
4T80-E
No Fourth Gear
Checks
Causes
1-2 Shift Solenoid Valve
Inoperative
Debris
Pinched wires
3-4 Shift Valve Bore Plug
Misassembled
4th Band
Burned, slipping, missing
4th Servo Cover
Cracked
4th Servo Pin
Broken, seized
4th Servo Piston
Damaged
4th Servo Seals
Rolled, cut or damaged
4T65-E
Slipping or No Fourth Gear
Slipping or No Fourth Gear Checks
Cause
DEFINITION: A large engine RPM increase is noted in fourth gear, Drive range, with little or no vehicle forward speed increase. First, second, and third gear operation are normal. Shifts into fourth gear are soft or do not occur. Fourth gear ratio is 0.705:1.
Automatic Transmission Fluid Level
Low fluid level
Transmission Main Line Pressure
Low transmission main line pressure
Oil Filter Assembly
• The oil filter assembly (100) is missing, plugged, or damaged.
• The oil filter seal assembly (101) is missing or is damaged.
Control Valve Body Assembly
• The 3-4 shift valve (362) or the 4-3 manual downshift valve (360) is stuck or binding.
• Debris is found in the passages of the control valve body (301) or of the control valve body spacer plate and gasket assembly (396)
Case Cover Assembly
Distortion or damage occurs at the manual valve (404) or at the case cover (401), causing PRN oil leak.
Driven Sprocket Support Assembly
A plugged third clutch oil passage in the driven sprocket support assembly (609)
Fourth Clutch Assembly
• The clutch plates (500-502) are worn, damaged, or misassembled.
• A missing or not seated fourth clutch spring retaining ring (601)
• A damaged spring assembly (602) or piston (603)
• Worn or damaged fourth clutch piston seals (604, 605)
Third Clutch Sprag Assembly
• The sprag (720) was misassembled or backwards on the inner race (661).
• A damaged third clutch sprag assembly (653, 661, 719-721)
Dec 06, 2015 | Pontiac Cars & Trucks
92 dodge ram 150 not shifting
Two things happen on the Dodge's. 1. the rear O2 sensor shorts out and meses things up. 2. the Inner seal on the Direct drum (3rd) shrinks and causes a delayed up shift.
Aug 05, 2008 | 1996 Dodge Ram 1500 Club Cab
1995 chevy regular cab 4.3l v6 2wd wont go into overdrive
Sounds like it is stuck in second gear. Overdrive only drops rpm by a couple hundred. In third gears you should still be less than 3,000 rpm.
Second gear is a default gear when the transmission is in limp mode. Is the check engine light on? Does it shift if you manual shift through the gears with the gear selector?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 21, 2014 | 1995 Chevrolet C1500
2000 Buick Century 69k mi. automatic trans. hard thud changing from 1st to 2nd gear, whining noise between gears
No idea without a drive so please ask a local mechanic to have a look for you
Dec 19, 2013 | Cars & Trucks
Automatic transmission
have you had the filter in thepan changed and oil changed in the tranny?
Jul 05, 2009 | 1994 Plymouth Acclaim
Car stuck in gear
Is it an automatic or standard? If it's standard, check the shifter cable, automatic, I would do a fluid flush, change the tranny filter, and make sure the pan isn't bent. I know someone who had the same problem, they thought they needed a new tranny, but they just needed a new filter (cost a couple bucks at the auto parts store), and then they noticed the pan was bent, which wasn't allowing clearance for the larger gears to be engaged.
Mar 29, 2009 | 1994 Dodge Ram
Volvo 240 GL Transmission
You have an overdrive relay issue. The tansmission is really a four-speed box, but the OD selector either locks our fourth gear or allows the car to shift normally into fourth. I use the OD on my volvo all the time, because the revs drop in half when the OD is activated, The relay is located behind the glove box, toward the center console. $10 buck on Ebay and your transmission should shift correctly again. I would try that BEFORE more expensive fixes, like OD solenoid $200 or transmission control module. Just for kicks a picked up a spare ECU on Ebay for $10 because these get costly if and when they go. Easy fix, though, a couple of plugs.
Jun 12, 2008 | 1989 Volvo 240
Cell Phones Logo
59 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
