Question about Maytag Neptune MAH5500B Front Load Washer
Leak from small hole in front bottom of neptune 5500
  • 1bodyman Nov 30, 2008
    this hole is not in the boot but in the bottom right front cover of the water resovoir, appears to be overfilling,ordered a new fill sensor switch,maybe will fix.
  • 121 Answers
The front boot can be patched with silacone if it a small hole but it must be clean and dry
Posted on Nov 29, 2008
  • sdmc73
    sdmc73 Nov 30, 2008
    the water presser sensor is not bad clean the presser hose if it is over filling but where is the leak from
Water leaking out of bottom of maytag Neptune front load washer
Check the door seal gasket for splits or holes
May 15, 2012 | Washing Machines
Hole Rubbed in Bottom Door - Leaks Through Front
If you can get to it you can use an epoxy made for metal or something like jb weld to patch the holes.
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B leaks. The leak is from a small hole in the outer plastic drum. The hole is at the six o'clock position where the large pulley that turns the inner drum is attached. There is a...
You most likely need a new outer tub,the bearing seal is shot eventually it will get gradually louder in spin if it hasn't already,you can try having the seal replaced and that may stop the leak but the damage to the bearing is already done.
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do i remove the back of my 5500 neptune shell?
you dont. it is serviced from the front. open the door, there are two screws on each side in the door frame, remove them (the door will stay without the screws until pulled up and out). pull the front panel toward you from both sides, then pull up out of the brackets on bottom. you can service any part in the cabinet from there. if you are removing the drum, youll see one screw on each side holding the top down, remove and top hinges up and out of the way. shane
Aug 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Our Maytag Neptune Front load Model MAH6700AW seems to alway have a wet or damp spot underneath or in front of the door. Where should I start looking for the leak?
the door has a series of small holes in the front bottom lip of the door gasket these are for drainage if they get clogged the door will drip water clean them and, remember to use HE soap
May 11, 2009 | Maytag Neptune MAH6700A Front Load Washer
Maytag Neptune mag9700 leaking water from bottom
to get a better look at where its cominf from take it apart by removing the screws from around your vdispensor as well as the ones out of the door and the other side . then there is 2 5/16 screws under neath the lid once you remove the front take them out then u can see where its leaking from . odds are its it either your boot or hoses to your valves.
Mar 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaks from weap hole in bottom of the plastic housing
The Maytag's have always had problems with those front door boots leaking and not draining thus leaving a bad mildew smell. What the problem probably is is that the hose that connects to the weap hole is cracked and needs replacing. I would suggest just replacing the entire boot along with the hose. The boot is a pain to replace though, it might take a tech to get it done for you. Let me know if you have any other questions and let me know if this information was helpful. Good luck.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leak at front of washer
You should have a drain at the bottom of the rubber boot inside the washer. There is a possibility the drain hose clamp came loose or the boot has a hole in it. If you take the front of the washer cabinet off, you should be able to see where the water is coming from. Take the two screws out of either side of the door opening, pull on both sides of the front panel at the same time, tilt downward, and the panel should come off.
Neptune washer
check arround the rubber bellows that the door seals aginst, maybe a hole in it, could be a pump leak drain hose leak
a lot of could bees i know but one of these
Apr 09, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
