Question about Sewing Machines
Kenmore 385.1960180 after removing the belts we have found that it is the drive shaft that appears be be bound up. it is very hard to turn. is there any way to loosen it?thanks for you help.
  • 41 Answers
Hi Nancy,
If it's been awhile (more than a year or 2) since you had the machine serviced, it may be something as simple as a good, thorough service. There is grease on some of the gears that periodically needs to be cleaned out and replenished to keep things running smoothly. Over time this can dry out and cause the drive shaft to not function properly.
It could also be a gear that is broken (a possibility) or the machine could be out of time (not likely, but also possible).
Unfortunately these are things that are generally not user-serviceable. Hopefully you have a good repair technician in your area that you trust - preferably one that is specifically trained on your machine.
Hope this helps.
Happy stitching,
Kim & Linnette
Posted on Dec 03, 2008
  • Kim Fillmore
    Kim Fillmore Dec 03, 2008
    Hi Nancy,
    Us again - forgot a bit of info.
    If this is an older, non-computer machine, and you can see the gears and determine if any are cracked/broken, you can try oiling the moving parts inside the machine (wherever metal rubs on metal), manually rock the handwheel backwards and forwards and see if that helps loosen things up. Use a little bit of "muscle" but don't force the driveshaft to turn. Just keep rocking it back/forth and add a little bit more oil at a time if you see any improvement.
    DO NOT attempt this if your machine is a computerized model as you can do further damage.
    Sorry I forgot to add this to the previous of those days!
I have a Kenmore 158-3500 sewing machine and cannot get the side plate off near the hand wheel I have removed the clutch wheel but the hand wheel and belt seem to keep the plate from coming off.
The machine has two belts, one from the motor to a transfer pulley and the second from that pulley to the handwheel. You have to loosen the motor mount (one large screw/bolt) to release tension on the transfer pulley which in turn releases tension on the handweel belt. You will have to take the belts off the transfer pulley to slide the handwheel off (assuming you have already removed knob in the center of the handwheel)
Don't forget to lubricate the shaft of the transfer pulley while you have the end cover off. If this runs dry you will have a problem.
Good luck
Jan 22, 2017 | Kenmore Sewing Machines
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
Kenmore sewing machine feed dog
Probably it is the spring loaded cam on the lower shaft not moving as it is bound up. The feed drop lever pushes it to the left to lower the feed dogs, but it has to spring back on its own after you move the lever back.
If you can remove the lower free arm cover you may be able to work it loose. Do not use 3 in 1 oil as it is gummy. Better to get Lilly white sewing machine oil.
Hope that helps!
Mar 12, 2014 | Sewing Machines
Model 1400 manual
there should be a small stop screw to prevent the release knob undoing completely. Did you remove the knob and hand wheel?
If so remove it again and ensure the drive belt is fitted on the hand wheel, there is a friction washer that needs to be located in the slots on the shaft before the knob is refitted.
Feb 09, 2014 | Kenmore Sewing Machines
Kenmore Sewing Machine 1703 belt
turn the hand wheel, perhaps?
Feb 05, 2018 | Kenmore Sewing Machines
The clutch on my kenmore 1310 won't disengage when i go to wind the bobbin. i turn the clutch knob toward me, and the clutch is still engaged.the machine needle continues to operate while i wind the bobbin
May be one of two problems.
1st you should be able to turn the nob about 90-120 degrees. Not a full turn.
If this is not the case follow these steps.
Turn the small screw on the nob about 2 full turns
Carefully turn the nob all the way off.
Inside there is a round part with 3 small prongs on it.
spin that 180 degree and put everything back together.
2nd your clutch is gummed up
You will need to remove the handwheel and motor belt for this.
Remove the nob, small 3 prong part, and motor belt.
Pull the handwheel off (it may be stuck on and hard to get off).
Clean inside the handwheel and the machine main shaft.
Lubricate the Main shaft and put handwheel back on.
When you put the small 3 prong part back on it needs to have the prongs sticking away from the machine.
Hope this fixes your machine
Apr 06, 2011 | Kenmore Sewing Machines
I am having a problem with the hand feed. It is slipping, and spins on it's own without engaging the main shaft. If I push in towards the shaft with my hand on the plastic hand feed, it will engage. But...
I think that you have a broken belt, or it slipped off of the shaft. Open your machine, by removing the screws and take a look. Belts are not hard to get.
Nov 18, 2010 | Singer Sewing Machines
Bobbin winder on kenmore model 148 15600 not working
I have the same model machine with the same problem!
The shaft of the bobbin winder 'froze' (apparently from old or incorrect lubrication). When it froze, it's rubber wheel (which they call a 'ring'') that is driven off the back of the main hand wheel (to the left of the winder) developed a flat spot, so it also had to be replaced. (Enter the machine model number at / to see how it fits together. Their exploded parts diagrams are excellent.)
Two screws hold the top cover on the machine, and two screws hold the bobbin winder to the underside of the cover. Note that the winder assembly mounts are slotted, so when reassembling, the winder must be adjusted to engage with the drive wheel. (Note its old position.)
You might be able to use a penetrating oil to clean the bearing without dis-assembly of that shaft from the bearing, but that didn't work for me.
I tried to get a whole new bobbin winder (Sears pt # 214458), as well as a new ring (Sears pt # 61662). but Sears no longer stocks that.
I found the ring cheapest at, but they no longer had the winder.
I found both parts at, but before the order arrived, I was able to repair the old one, so if the winder does arrive I'll have it as a spare.
I made a fixture to remove the press-fit wheel (that mounts the ring) from the shaft, so I could clean and re-lube the shaft bearing. I used a lathe to drill a 8mm hole > 40 mm into the end of a 1/2 in. aluminum rod, and mounted the rod in a press, and used a 3/16 steel pin to push the shaft out of the wheel. Clamping the rod in a vise and using a pin punch /hammer might also work, but it was very hard to separate them, so that might not work.
When lubricating the shaft/bearing of the winder, be sure to use a good quality sewing machine oil. I've had bad experiences with bearings like this lubed with generic oil (like 3-in-one oils) which gummed things up in a very short time.
Good luck
Paul Higgins
Sep 30, 2010 | Kenmore Sewing Machines
I've removed the Timing Belt on my Wifes 3820
adjust your tension, change your needle and adjust also your rotating bar.
Mar 27, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
161 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
