Question about Apple iMac 24" Desktop
Imac-samson-gtrack mic compatability
Can the g-track be used with an i-mac?.
    Problem Solver:
  • 5 Answers
From the Samson Audio website...
"Ideal for the traveling musician or the project studio, the G-Track ships with a desktop mic stand, swivel stand mount, USB cable and all the cables needed to connect any musical instrument with a standard 1/4" or RCA output. The G-Track ships with Cakewalk's Sonar LE and works brilliantly with Apple's GarageBand."
If it states that it works with GarageBand, I would say that it would work on a mac.
Posted on Dec 07, 2008
I connected the microphone on my computer and the system rec.ognized the microphone but I don't know how to use it with the computer to bring out sound
The thing is that the Samson C01U was not designed for live applications. Your solution, if you like delayed sound, is to use Virtual Audio Cable. Otherwise, I would get either a Samson GTrack, or invest in a cheap but functional mixer with a good mic. If you want to record however, you go into your audio recording settings and select the C01U as the recording mic. If you record and hear little sound, go into sound manager... Click on properties and select on Samson C01U. A one channel volume control will pop out. change the volume and record. BTW, a good audio program is Audacity... It's free. I hope that I have helped you...
Apr 27, 2011 | Samson C01U Consumer Microphone
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Problems with samson g track usb mic
sounds like your recording volume is too high, and its "clipping"
Mar 03, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Many Problems with Samson G-Track or not?
Hi.  I dunno if yur using pc or mac but with a mac yu need to adjust the mic settings on the comp. For the static its probably your set up or as i said in another guys problem, the usb cable given with it is **** so try using another one from a printer or wtv to see if that makes a difference for you. Also if you are recording just through the mic i find that it seems to only work well when the input is on line and not inst/mic. Hope this can be of some help. Its a great piece of kit once you get it working well.. Goodluck
Jan 16, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
I recently purchased a samson g-track usb mic. when I use it with garage band on my imac - I get static. not always, only about 1 time in 10 recordings. I have to diconnect the mic, re-connect then it...
It appears to be a problem with USB and the clock sample rate of the mic.  You need to go into your Applications/Utilities folder to find your Audio MIDI Setup.  In there you can choose the device for input and manually set the sample rate (usually 44.1K or 48K).  Keep that window open while you record, and you'll find that the mic will reset itself to another sample rate on its own... don't know why, and Samson's support is pretty non-existent, so I can't get any answers from them.  If you simply reset the sample rate in the Mac's Audio MIDI Setup utility the problem will clear itself up.  But, with Garage Band, you'll then get a very bad latency issue that will force you to restart Garage Band to reestablish a near-zero latency.  It's annoying, but it does work.  (In Soundtrack Pro I can reset it without having to restart the application.)
Nov 25, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
No driver
What operating system are you running on? The manual says it requires mac os x - try that?
Sep 30, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
STATIC!
Hi philltl89
If it has been doing this since new, there is probably something wrong with it. I would return it to the place you purchased it from and get it changed over.
regards
robotek
Jun 18, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
GTrack producing NOISE and not catching audio from even 20cms.
Did you check the record levels on the software you are using.
Sep 14, 2007 | Samson G-TRACK USB RECORDING MICROPHONE...
Apple iMac 24" Desktop Logo
120 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
