Question about Sony RDR-VX525 DVD Recorder/VCR
Unknown disk error on insignia ns-drvcr
My dvd/vcr ecorder will play disk when it wants to and gives unknown disk error the rest of the time.I eject the disk and reload it several time and will eventually get it to work
How d i fix this problem?
  • jgill21 Nov 30, 2008
    Have already tried to clean lense but still having problem
  • Sibananda Jena
    Sibananda Jena May 11, 2010
    Try to clean the lens using lens cleaner...
SOURCE: Insignia DVD recorder/ VCR Combo - won't accept a VHS tape
MANUAL
Posted on Oct 01, 2008
sree-here
  • 61 Answers
SOURCE: Insignia DVD/VCR NS-DRVCR won't read dvds
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Posted on Mar 13, 2009
John-INSG
  • 312 Answers
SOURCE: I have an Insignia TV and need the Sony remote code
According to InsigniaProducts.com, code 8043 may work for Sony remotes for your model of TV.
Posted on Aug 07, 2009
  • 11800 Answers
SOURCE: The DVD blank disk is
The laser head is covered in dust so the sensor detects a very low return signal. This is interpreted as a bad disk.
The sensor must be cleaned. Open the unit, access the mechanism and do a thorough cleaning inside it, access the laser head and using a can of compressed air blow all the dust on, in and around it - be especially thorough with the space between the lens and the sensor. Finally  wipe the lens gently with a q-tip.
If this doesn't completely eliminate the problem then the dust has been baked on the surface of the plastic lens - this is unfixable you will have to replace the laser head, the entire mechanism if you can't find just the head.
Posted on Sep 13, 2010
  • 6771 Answers
SOURCE: my Sony Blue Ray has
If you can play standard dvd movies without a problem, then you are looking at a laser pickup assembly issue. The blue ray disc require more precision to provide the higher resolution when it is demanded, this is an early indicator of impending failure in the assembly. However there is a small chance that cleaning the laser pickup lens may solve the problem but unlikely.
Posted on Dec 29, 2010
Testimonial: "Thanks for the quick response, I will see if cleaning helps first. Greg,Texas"
Instructions on how to burn from my insignia DVD to VHS
my Insignia is a different model (NS-drVCR) but I always use the "DUBBING" button on the remote (which is basically the tech-term for a Recording-Transfer). The screen-dialog then shows VHS Dubbing to DVD with quality options to choose. I'm not as familiar with going the other way (from DVD to VHS) but I know that mine can since I've done it once with a similar method, starting with the DUB-button.
Jan 11, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvd won't play back on another dvd player
Has the DVD disk been FINALIZED? my Insignia is a different model (NS-DRVCR), but I'm guessing they might work the same where one of the menu options is to Finalize your disc. This makes it so it can be read in other players.
Dec 29, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Mar 12, 2009 | Insignia NS-DVDR1 DVD Recorder
Lost instructions, cannot create DVD from cam-corder recording
Thanks, I already solved the problem. There was no "Setup" button (on the remote, anyway) to follow the instructions given -- in the manual, which I downloaded!.
Instead, I remembered that "Input" often allows you to select a source for something, so when I chose THAT button, I was able to choose the port that had my cam-corder.
Then I simply pressed record on the DVD player while Play on the C-C.
Mark H.
Dec 15, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Cannot finalize a dvd.
being that it is a display model , there are acouple of things it could be
first try cleaning the laser lens with a disk that goes in there , if that don't let it finalize then the laser lens should be cleaned manually, and if that don't do it then there is an internal problem ,which then it would need repair
Nov 11, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia dvd player wont play some discs
How to unlock a dvd player Insignia NS-H2002-U for region free
Insignia NS-H2002-U
With disk In the player (must be allowed region on you dvd)
Press stop in the remote dvd control 2 times to have a dvd screen in your tv
Press 16719 in your remote no matter what appears in the screen, at the end the region menu will appear
Using down arrow go to region that you want, “0” is for region free.
Press ok and enjoy it.
If do not work, power of your dvd, turn on again, incert allowed dvd movie in your insignia dvd player, when start reading disk, press stop and the press setup in your remote control, set uo dvd screen appears, then press 16719 in your remote, region menu will appear and use down arrow to select your region code, zero is for all regions.
Enjoy it
Feb 17, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Recording
BINGO!!!! YOUR DRVCR MUST HAVE A BUILT IN TUNER TO DO THIS
Jan 29, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvd won't play
sounds like microprcessor board failure the best thing to do is get a new unit
Nov 27, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia nr-drvcr
After you record, you must go to menu and finalize disc. Have you done that? jafreeb@excite.com
Aug 28, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Sony RDR-VX525 DVD Recorder/VCR Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
