Question about Kenmore Oasis HE 27082 Top Load Washer
Very load when spining
This machine came with our hous but was just two months old,this was 18 months ago. It was the quitest washer ever but now it sounds as if a bearing is out or going out when it spins.
Is there a history with this problem with ths machine? Would this be an easy fix??
  • 121 Answers
Sorry this is comon,and yes it is a bearing the top seal leaks water in the bearing. So you need a seal kit and top bearing and mostlikly a belt
Posted on Nov 29, 2008
I Bought a Bravo series 300 Washer and Dryer 18 months ago. They came with a 1 yr. manufacture warranty The first month I had problems with the dryer which was covered under warranty.. It was inconvenient...
hi,
usually most areas have a USED appliance store. usually these guys will have a bunch of old fridges and stoves around outside the store. Our town has three or four of them. you may have to ask around but these guys usually have parts for cheap. and they will sometimes make house calls. try googling used appliances in your area. they may also set you up with a cheaper washer with a METAL tub.
good luck
jm
Nov 15, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
"ZWF160070W1 Washing machine. Only 18 monthe old!
I would start by checking the filter and cleaning it, this is usually located at the bottom right front of washer behind a flap or cover, unscrew an ti-clockwise to remove and clean.
Nov 14, 2010 | Zanussi WJD1257W Front Load Washer
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
Won't turn on - press the start button and nothing. hold it down and it will light up, however water will not start nor does the cycle start. Unplugged it and replugged back in, tripped the circuit and...
Husband came home from work - looked at what was happening. It appears service is needed due to circuit board issue; technician will be at house this am.
Sep 16, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore washer elite top load makes nosise when spining.
If it also tends to walk around, there are pads under tub supports that tend to wear out in this model. They are easily replaced.
Sep 04, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Service light is on my whirlpool washing machine and won't allow the wash to start, can I override this as it's only 18 months old?
The main motor in the whirlpool front loaders has brushes. These will wear out eventually. Does the drum try and turn when a load is started? If not the motor deserves a check. 18 months sounds short but possible. Mine took 4 years to wear down.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bearings on Hotpoint
the unit is only 18 nmohths old then what you need to do is contact the manufacture and explain to them what is happening and if they are having simuary isssues with that particular moidel number. Possibly they are and you may be able to have it repaired on their dime! 18 months is not that long for a washer to start having these problems if you have not abused the unit by overloading the washer or over filling it with soap. Good Luck
Jan 05, 2009 | Hoover AAA160 Front Load Washer
Kenmore HE4T Washer Leak
there are 2 possible causes.
either
inlet valve leaking - turn water off and if water fill stops, it indicates valve leaking
valve being powered when machine off. this is very unlikely but to check, disconnect washer and see if problem stops
also, if drain is plumbed into a spigot on the sink trap, every time you empty the sink, some of the water will flow into the machine. to cure this, take the drain hose as high as possible under the sink in a swan neck
Oct 20, 2008 | Kenmore Elite 45986 Front Load Washer
My new front loading washer is not spining. It is 3 months old. We have a 12 month warranty and labor
call whirlpool customer service, they own maytag now, you will be covered under warranty.
Mar 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle
hold cancel for 10 secs
hold end of cycle signal 10 secs.
one of them should reset it.
Feb 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
87 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
