Question about PSC Quickscan GP5385 Handheld
Programming GP5385 to scan 20 digits
Hi, I would like to know how to program the GP5385 to able to scan 20 digits. Right now it can only scan 15 digits. Regards, Huygen
    Problem Solver:
  • 20 Answers
Dear Huygen, Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it by scanning it to factory configuration,or scan a label that would enable all symbologies.
Posted on Aug 25, 2007
Trying to get installer code on Honeywell Vista 15-P
hit *20 then put in whatever 4 digits you want as installer code. write this down on your program sheet for future reference. yes, you should have a program record sheet to follow and know how to navigate in programming or else you could make things worse.
Jun 29, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
How do i program the remote for my car?
PROGRAMMING REMOTE KEYLESS ENTRY TRANSMITTERS (RKE)
1. Install scan tool
2. Turn the ignition switch to ON - do not start engine
3. Select "Remote Function Actuation" with the scan tool
4. Select "Special Functions"
5. Select "Program Key Fobs"
6. Select the number of key fobs to be programmed
7. Press and hold the LOCK and UNLOCK buttons on the first transmitter simultaneously for approximately 15 seconds. The door locks should cycle (Lock and unlock) to confirm that the programming of the first fob is complete.
8. If you are programming more than one transmitter, repeat the previous step for each transmitter for up to four transmitters in total.
9. Remove the scan tool
10. Exit the vehicle and operate transmitter functions to verify correct programming and operation.
Apr 20, 2011 | 2003 Saturn L-Series
Do not know how to set timer DT300 for Lights
Hi
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Thanks.
Dec 27, 2010 | Audio Players & Recorders
Scanner will not accept any freq with 4 digits to the right of the decimal. Is this a scanner limitation or am I just not very smart : ( Thanx
You can enter up to five decimal digits, but the 4th and 5th are limited to 25, 50, or 75. These do not show as full sized digits during programming, scanning, or searching, but should be displayed as small digits to the right of the full-sized numerals - as shown on page 15 of the operating manual. I hope this helps.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC340CRS%20%28Manual%29.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Nov 09, 2010 | Uniden BC340CRS Base Scanner
How do you set the scanner to your local police or
First you need to know what frequencies are in use in your area. For a comprehensive database, visit:
To enter (program) a frequency for future scanning:
- Slide the MODE switch to Scanner
- Press the E (PGM) key. This will turn on the PGM indicator at the top right of the display.
- Press the UP or DOWN arrow (above the SCAN and HOLD keys) to advance to the desired channel, OR enter the channel number using the keypad.
- Press HOLD
- Enter the frequency, including the decimal point (e.g. 155.67).
- To continue programming, use the UP or down key to advance OR enter a channel number, press HOLD, and continue programming as above.
When you're finished programming, press HOLD or SCAN.
I hope this helps. I have a BC370CRS on my desk, and I found that the programming is fairly simple -- once I got used to it.
NOTE: The BC370CRS will NOT work with trunked or digital radio systems. If these are in use in your area you will need a different scanner to listen in.
Dec 25, 2009 | Uniden BC370CRS Base Scanner
Car key remote
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Mar 24, 2009 | 2001 Ford Expedition
Quickscan psc GP5385-need a program manual
You can download a manual (06656 User's Guide/Programming Guide) at the DataLogic site. They bought PSC in 2005.
http://www.scanning.datalogic.com/sitefiles/result.aspx?m=Product%20Manual&p=53XX&l=english&d=1&t=search&s=NonCurrent
Caps Lock settings are on pages 36 & 37.
Label_Guy
Oct 02, 2008 | PSC QS6000 Plus Handheld
I need an owners manual
If your cables are connected between your keyboard and PC, be sure to set up the correct Keyboard Wedge Parameters, beginning on Page 34, to allow connectivity.
I'd start by scannig barcodes "CE" and "ZA" to reset to default wedge values. If that doesn't work, I'd procede to sc an "CF" for PC=AT,PS/2.
Pages 36 & 37 address the Caps Lock issue, where the scanned value is in the wrong upper or lower case.
Have a nice day,
Label_Guy
Jun 12, 2008 | PSC Quickscan GP5385 Handheld
Programming favorite channel scan
After you hold down the P button and the leds blink you put in 996 then the led's blink again. Once this happens all you do is put in the channel you want as a favorite, and then hit P For codes less that 4 or 5 digits you hit the enter key. ANd it isn't clear how many digits to put in for a channel with 2 digits but it looks like if you put in anything under 99 you will want to put in 099 098 097 etc etc... Hope that helps some
Aug 27, 2007 | Radio Shack (15-2147) Remote Control
GP5385 incompatible with EAN 13
Dear Akiong, Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it by scanning it to factory configuration,or scan a label that would enable all symbologies.
Aug 24, 2007 | PSC Quickscan GP5385 Handheld
PSC Quickscan GP5385 Handheld Logo
255 people viewed this question
Top PSC Computers & Internet Experts
Tom Chichester
Terry
Terry
Paul Jones
Paul Jones
Level 1 Expert
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
