Question about Abit VA-10 333MHz FSB VIA VT8378 Chipset Socket A Motherboard with AGP 8x, LAN, 6 Channel Audio, USB... (MBSAABVA10SA)
Changed cpu on an abit va-10 mb but the fsb stays at 266
I have upgraded a pc to an athlone 2500, the fsb for this is 333, but the bios seems to only set 266, so the new cpu is no fully recognised.
the mb is an abit va-10. how can i change the fsb
  • Howard Lester May 11, 2010
    what is the speed of your ram?
    Scholar:
  • 172 Answers
Unless the mobo is compliant with a front side bus speed of 333mhz, the cpu you have will only run at 266mhz max, in other words the cpu will down-clock to the 266mhz bus clock and therfore run more slowly. check with the mbo handbook, or on CMOS tosee if yoy can change the fsb setting. ask for more help if needed.Can you give me the full code of the mobo ?
Posted on Dec 01, 2008
What is the upgrade cpu for this motherboard
The following processor are currently supported by this mainboard.
Athlon XP: 1500+ up to 2000+; FSB: 266 MHz
Athlon: 650 MHz up to1.4 GHz, FSB: 200 MHz or 266 MHz. Socket A CPU. See page 10 in you're manual (If you still have one). After going to Elitegroup and checking for the latest bios version;
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=67&CategoryID=1&MenuID=50&LanID=9
BIOS for K7VMM(PCB:1.2A). Release date, 2003/03/28
The MB will support, AMD Athlon XP 2400+ and 2600+ CPU If you're bios is flashed to the above. You can buy and use this CPU; http://www.sjkksales.com/servlet/the-461/AMD-ATHLON-MP-2600/Detail
Never flashed a bios? Instruction are listed on ECS web site.
Mike
Jun 13, 2010 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
BIOS error - CPU is unworkable or has been changed
try to reset cmos by removing CMOS battery from motherboard and reinsert again...
Dec 12, 2008 | Abit KV7-V Motherboard
KV7 upgrade
you might be in luck, the last bios update covers 266 / 333 and 400 fsb cpu's
have a look here
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=2&model=230
Mar 13, 2008 | Abit KV7-V Motherboard
Upgrade
Thank you for the information. Please find the CPUs supported by the Motherboard of your computer below.
Duron: 1.6 - 1.8 GHz at FSB 266 MHz
Athlon XP:
Palomi** Core: 1500+ - 2100+ at FSB 266 MHz
Thoroughbred Core: 1700+ - 2700+ at FSB 266/333 MHz
Barton Core: 2500+ - 3200+ at FSB 333 MHz
2500+ - 3200+ at FSB 400 MHz
Sempron: 3000 + and up
I see that the present processor is requires ** upgrade as it is one of the best match availble for this motherboard. However, you can upgrade the Memory to 2 GB using two 1GB
DDR 266/333/400 modules to improve the system perform performance. Also, you can consider for a video card upgrade. Your computer supports both AGP and PCI video cards.
Also, you can download the maunal for the motherboard of your computer from the link below for your referance.
http://www.elhvb.com/mboards/oem/emachines/manuals/K7MNF-64_manual.zip
Regards
Mar 07, 2008 | Computers & Internet
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
amd 3200 + anthlon ok with fsb 266 mhz soket a
Jan 10, 2008 | ASUS A7S333 Motherboard
CPU Upgrade
Athlon XP 3000+ is 400mhz FSB according to the link(http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_1274_3734^11672,00.html), means that in order to display the actual speed of your Athlon XP 3000+ you have to set your board 166mhz to 200mhz jumper setting or in CMOS utility overclocking option. and also just to inform you that your motherboard is in Overclocked condition when set, because it only supports processors up to 333mhz FSB (http://www.digital-daily.com/motherboard/soltek-sl75frv/)
Sep 11, 2007 | Soltek SL-75FRV Motherboard
Processor
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Jul 16, 2007 | Compaq Athlon XP 2000+ , 1.67 GHz...
Computers & Internet Logo
96 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
